Metro Bearings In Mini Hub
Posted 15 November 2012 - 09:45 AM
the discription mentions they use metro bearings,
i there any advantages of using the metro bearings ?
Posted 15 November 2012 - 09:58 AM
Id' check that the hubs are mini hubs adapted to accept metro balljoints, but if the casting is the metro hub, i wouldnt even consider it due to the different king pin angle.
Plus i wouldnt fit alloy front hubs in anythng road going, they're intended for track use really.
Posted 15 November 2012 - 10:04 AM
Posted 15 November 2012 - 10:06 AM
Bearings are the same, its the balljoints and the inner CV joints that are different on a metro.
ok cheers, im doing my motorsport dissertation on the mini hubs/uprights, i will be runing the standard ones through various software and optimising them or redesigning them, so im looking at whats avaliable now and was just wondering if there was any advantage to the bearings,
as for running an alloy front setup providing, with alluminium it would only be the fatique strength that could cause a failure after XXXmiles, other matirials suchs as titanium would probably be ok for road use however i will be simulating this in a track cornering condition and braking thenhitting a pot hole, so will find out if they are road worthy
Posted 15 November 2012 - 10:10 AM
Being lighter they'll put less strain on the bearings, but i can guess the difference will be very very marginal
Posted 15 November 2012 - 10:18 AM
post holes is shock loading
Posted 15 November 2012 - 10:21 AM
Many people have used the ball race bearing on minis fitted with disk brakes, mainly because they are significantly cheaper than timken, however I'm not sure that this is an economic solution... It all really depends upon suspension set up, where the wheel centre is opposed to the king pin angle etc etc
Posted 15 November 2012 - 10:32 AM
still havnt put mine in my mini since you built it :/
