How To Remove A Pedal Box
13 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 18 November 2012 - 02:38 PM
I have an auto im converting to manual but how do i remove them snapped off bolts underneath
#2 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 18 November 2012 - 02:47 PM
You have undone the nutsthat hold the master cylinders in? The studs are in the pedal assembly
#3 minilee94
minilee94
  • 3,523 posts
Posted 18 November 2012 - 02:52 PM
Yeah il upload a pic now
#4 minilee94
minilee94
  • 3,523 posts
Posted 18 November 2012 - 02:55 PM
Ahh this sh@t phone wont let me up load it
#5 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 18 November 2012 - 02:56 PM
Ok. Best get describing!! What bolts have sheared??
#6 minilee94
minilee94
  • 3,523 posts
Posted 18 November 2012 - 03:04 PM
Nar none have broken its a domed shape bolt but nothing to get hold of no sides or anything to get a socket on to i take it its a safety thing
#7 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 18 November 2012 - 03:06 PM
you only need to fit the clutch pedal and relivant spring, you do not need to change the pedal box its self :)
#8 Artful Dodger
Artful Dodger
  • 4,435 posts
Shear bolts! Either weld a bolt to it and you are sorted or use a chisel to knock it undone
#9 tiger99
tiger99
  • 8,584 posts
Posted 18 November 2012 - 03:19 PM
Or grind the head off, or centre punch it and drill straight into the end with a drill at least as large as the bolt diameter, which will be 5/16", until the remains of the head seperates from the shank.
Shear head bolts are a real nuisance. I am not sure about the legality of replacing them with something else, as they were a measure introduced by law to attempt to prevent theft, but if you are not worried about that aspect (and I don't think it is checked in the MOT), a mushroom head allen bolt makes a reasonable replacement. Allen bolts are usually grade 10.9, which is one grade up on the original, and therefore more than strong enough, while looking neater than the standard hex head bolt I used last time I had to drill one out.
#10 sledgehammer
sledgehammer
  • 3,109 posts
Posted 18 November 2012 - 03:30 PM
you can also tap a ball bearing in the allen head with a drop of locktite if you want to secure
but it may be a bugger to get it out
#11 tiger99
tiger99
  • 8,584 posts
Posted 18 November 2012 - 04:40 PM
Interseting idea, but I would be inclined to leave it until the MOT tester told me to deal with it.
#12 minilee94
minilee94
  • 3,523 posts
Posted 18 November 2012 - 04:46 PM
Hi guys thanks for all you input but have managed to take the shaft out and take off the clutch pedal from other pedal box
Another question tho my old pedal box has no springs on at all but new pedal box has spring onthe brake and clutch do i still fit the spring in or not cheers
#13 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 18 November 2012 - 04:50 PM
yes u need the sping else the clutch pedal wont return, so i take it u have a servo atm. and the pedal box u have is for a non servo car.
Also u can use the pedal box cut down for an ultimate engine steady mounting on the passenger side :)
#14 minilee94
minilee94
  • 3,523 posts
Posted 18 November 2012 - 04:56 PM
What you mean cut down for steady bar and yes i have a servo on the car so the spring will be okay even tho i got a servo
