Has Anyone Had Trouble With Locks
9 replies to this topic
#1 geriatric
geriatric
  • 43 posts
Posted 18 November 2012 - 06:49 PM
My passenger does not want to seem to lock. I'd it worth buying a second had one. Or is there a common issue with these.
#2 LukeMoss
LukeMoss
  • 398 posts
  • Local Club: TGSOC
Posted 18 November 2012 - 07:44 PM
Is the lock seized or does the key actually turn? When it's cold my locks like to freeze up so I can't lock or unlock them
#3 harrymini2012
harrymini2012
  • 236 posts
Posted 24 November 2012 - 02:06 AM
i have the same problem on the passenger door, it will turn with the key but only lock from inside.
#4 camp freddy
camp freddy
  • 3,696 posts
Posted 24 November 2012 - 08:17 PM
it could have unclipped from the rod , you will need to remove the door card..
#5 puggered
puggered
    previously known as Mini15
  • 708 posts
Posted 25 November 2012 - 01:11 PM
Exact same problem as mine but I fitted remote central locking to it last year so it lock and unlocks at the touch of the button now. I will eventually get round to fixing it so it unlocks off the key lol
#6 minimininut
minimininut
    Look Out For My Haynes Minature Engine Install Project
  • 830 posts
Posted 25 November 2012 - 01:40 PM
I've been having problems with my locks lately - my boot lock seemed to have water in it and you had to wriggle the key around a lot for it to work, and my driver's door sometimes didn't 'engage' the lock. I had a good search of TMF and the world wide web and found out about dry graphite lubricant. A local key cutting place sold me some, you can also get it on fleabay. Touch wood, it's solved both problems so it might be worth a try!
#7 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 25 November 2012 - 03:50 PM
Hi,
As Camp Freddy suggests, there is a small link rod thats runs from the lock arm on the door handle to the striker assembly mechanism. As you turn the key, the arm moves so moving the rod and locking the door.
I had exactly your problem when rebuilding my doors and the small clip that holds the rod to the lock arm had come off.
Whip the door card off or un-screw the striker assembly and you may just be able to reach the rod, depending on which end has come off!!
Hope this helps, Steve, :proud:
#8 harrymini2012
harrymini2012
  • 236 posts
Posted 25 November 2012 - 03:54 PM
im going to get the door card off tommorow and check it out, hopefully something has just come loose or unclipped like camp freddy said. il let you know how it goes.
#9 AC&SONS
AC&SONS
  • 127 posts
Posted 25 November 2012 - 05:35 PM
Hi,
This happened to my driver's door last week, meaning I had to scramble out of the passenger side if I wanted to lock both doors, not a good look >_< It was just the little clip that needed putting back on, and now it's as good as new =]
#10 harrymini2012
harrymini2012
  • 236 posts
Posted 26 November 2012 - 08:49 PM
had a look at mine today and as been said it was just the litte rod that came unclipped. only took 5 mins :)
