Water Pump?
Posted 20 November 2012 - 11:20 AM
The alternator belt has squealed a bit over the last few days, changed it at the weekend, checked the tension and it's fine but still squealed a bit when there was load on the alternator (like running with headlights, heater and wipers going...) and squeals when the problem happens - not that you can really hear it over the other horrible noises from under the bonnet.
Alternator's only 18 months old, but the water pump is older. Alternator seems to be working fine, charges to about 14V on the gauge, drops off a bit with the electrics going but goes up again with less load. Could the bearings have gone in the water pump, meaning it's struggling to turn the alternator belt? It ran a bit hotter than usual, but then again it's so cold in the mornings it was never going to overheat.
I need to try and get it home this afternoon, but don't want to drive it too far (20 miles to get back) if it's going to go bang. I have AA cover and there's a Mini garage round the corner from me, so I could get towed if something catastrophic happens.
Then again, I managed to recover the same distance with a cracked cylinder head a few months ago, including about five "water stops". I'm hoping it's just the water pump because that will at least be cheap and quick to fix!
Posted 20 November 2012 - 11:43 AM
Posted 20 November 2012 - 12:05 PM
Posted 20 November 2012 - 05:15 PM
Posted 20 November 2012 - 07:30 PM
Posted 26 November 2012 - 10:19 AM
Posted 26 November 2012 - 11:03 AM
Don't just go pointlessly throwing money at it, did you check the waterpump before you changed it?spend more cash on a new alternator...
What about the alternator did you check it was spinning free while the belt was off?
Back to the belt, why did you change it in the first place?
Posted 26 November 2012 - 02:54 PM
Posted 26 November 2012 - 09:20 PM
The alternator seemed to be spinning fine when it was all apart, and has been charging fine, but the squealing only happens when it's "under load" - like having the lights and wipers going, then stopping at traffic lights and the revs drop off. It is only a 36 amp one though, and it could probably do with at least a 45A version instead - for the winter months at least.
I changed the belt because (a) I assumed that was why it was squealing, (b) it was old and worn and © I'd tried re-tensioning it a couple of days before to stop the squealing.
Cooperman - there's plenty of tension in the belt, only about 10mm of play when you push it down between pump and alternator. Previous attempts tightened it even further and no change.
Posted 26 November 2012 - 11:31 PM
If the pulley can be freely spun by hand with the belt off then its not seized, If the pulley rotates cleanly by hand with no roughness, and there is no up\down or side to side play then the bearings are ok.
When checking that the alternator is charging - first check voltage with engine running and everything electrical turned off, anything between 13.8v to 14.3 is perfect.
Then check voltage with engine running and everything electrical turned ON, including all lights, hazards, wipers, stereo, blower fan. Anything between 13.5v to 14.3v is perfect. If the voltage drops below about 13.5v or ever rises much above 14.5v then you have a fault with the regulator in the alternator. If you see a high voltage then check the cells of your battery (if it has removable filler plugs on the top) as it may be boiling the battery.
However, your original problem of the car nearly stalling at low revs but being ok with more revs on sounds to me like a fuelling problem. This is a classic symptom of a blocked fuel filter. The engine struggles to pull fuel through at idle, but with the increased flow at higher revs then it is able to cope. Although if it is a blocked filter then it will only get worse. Of course any point in the fuel system that is gunked up or blocked will cause the same problem, wether it is the pick up in the tank or a dirty carb jet.
Edited by Vonski, 26 November 2012 - 11:33 PM.
Posted 27 November 2012 - 08:40 AM
Battery should be fine, it's a four months old Bosch silver bought after the previous one, a cheapie, packed up. Only had these issues for the last ten days or so, as it's undercharging rather than overcharging shouldn't have done any damage.
I think the car cutting out/stalling (which only happened on that one day by the way) may have been a temporary blockage somewhere, no problems like that since so it seems like a red herring.
I'm thinking that an alternator is only £50 from Minispares (I take it http://minispares.co...rs/GXE2211.aspx will be a direct replacement for the 36 Amp LRA100?) and not sure what else could produce these symptoms.
Posted 27 November 2012 - 01:16 PM
Replace it and all will be happy!
Posted 27 November 2012 - 02:10 PM
Posted 27 November 2012 - 10:31 PM
On the other hand, as your alternator seems to be suspect, I think that it probably has shorted turns in the windings, which will make it waste a lot of energy, needing more from the belt, which could well make it squeal. Worth looking closely at the pulleys though, it only takes a minute, just in case....
Posted 28 November 2012 - 08:39 AM
I'll take a look at the driveshaft pulley tiger, keeping my fingers crossed if any of them are problematic it's the alternator as that's being changed!
