Cleaning Subframe / Parts
12 replies to this topic
#1 charliebudd
charliebudd
  • 429 posts
Posted 20 November 2012 - 12:59 PM
I have stripped and sent my subframe of for powdercoating, i would like to clean up all the other parts and paint them. they are completely covered and grease and dirt etc. what is the best way to clean them up ? and what would you paint them with?
#2 MrBounce
MrBounce
  • 2,662 posts
Posted 20 November 2012 - 01:08 PM
I am doing the same at the moment with the Midas. I gave everything a good clean with degreaser, then used a wire brush on the angle grinder to get it cleaned up & keyed ready for paint.
I used Hammerite.
#3 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 20 November 2012 - 01:15 PM
Parts cleaner, then sandblasting, then re bush etc and paint!
#4 samsfern
samsfern
  • 5,243 posts
Posted 20 November 2012 - 01:19 PM
Or scrub it with petrol, just be careful of sources of ignition, lol.
#5 Barman
Barman
  • 1,068 posts
Posted 20 November 2012 - 02:05 PM
I used POR15 Marine Clean >>> Metal Prepare >>> PPOR15 paint...
#6 Minidarren83
Minidarren83
  • 1,207 posts
Posted 20 November 2012 - 02:24 PM
Dishwasher just don't let her indoors catch you lol works a treat
#7 Barman
Barman
  • 1,068 posts
Posted 20 November 2012 - 02:52 PM
Subby doesn't fit... >_<
Most of the rest of the car went through it though.... :proud:
#8 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 20 November 2012 - 02:55 PM
for the subframe definatly get it stripped completly and sand blast it! noting can get right into the cracks and corners and completly remove the rust!! and you get such a nice finish! like new! and it will not cost a huge amount. cost me 30 quid for 2 subbys.
#9 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 20 November 2012 - 03:20 PM
you can get rust treatment stuff from hamerite, you mix it with water then put the part into the water over night and it will remove the rust, then just a case of priming the part and painting it,
#10 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 20 November 2012 - 03:27 PM
It's not as effective as getting rid of the rust completely! Use that stuff and rust will return! But I'm not bothered, not my rusty subframe...
#11 Barman
Barman
  • 1,068 posts
Posted 20 November 2012 - 03:53 PM
I wasn't very impressed with it...
The POR15 Metal Prepare is amazing - most of my car went through a bath of it... It not only removes rust but also old paint and stuff... leaves an excellent surface for painting...
#12 JonnyBMX
JonnyBMX
  • 865 posts
Posted 20 November 2012 - 05:20 PM
oh right, i only ever used the hamerite one once after i brought it by mistake instead of the instant rust remover stuff, it seemed okay when i used it but then again i did scrub it with a tooth brush a few times in that 24 hours and your right the paint didnt totally come off and i had to scotch it all up b4 paint
#13 wbutcheruk2
wbutcheruk2
  • 49 posts
Posted 21 November 2012 - 08:46 AM
I agree shotblast works best, i used to work at a steel place so got my front and back subframes shotblasted, worked a treat. To protect bolt holes i used some old bolts. I did the smae when i got the frames powder coated too.
