Radio Static After Amp Install
Posted 20 November 2012 - 05:18 PM
Any ideas?
Posted 20 November 2012 - 05:58 PM
Posted 20 November 2012 - 06:52 PM
Posted 22 November 2012 - 05:56 PM
Posted 23 November 2012 - 08:16 AM
Posted 24 November 2012 - 05:27 PM
Posted 24 November 2012 - 06:49 PM
Maybe the amp install has just made you notice the sound?
Posted 26 November 2012 - 05:54 PM
Posted 26 November 2012 - 07:07 PM
but after alot of reading up if i remember correctly, if your pre out voltage is 2 volts rather than 4, then grounding the pre-outs to your head unit casing is suppose to stop the whining, this is what i have read up but i am yet to try it out for myself, but they say to wrap a wire around the pre-outs and bolt it to your casing.
Posted 05 December 2012 - 05:40 PM
thanks for the help
Posted 05 December 2012 - 05:47 PM
Thanks!
Posted 05 December 2012 - 07:41 PM
Yepp, the pre-out voltage is 2V. So why does this cause the radio to go fuzzy? Also why would they make them 2V if amps run on 4V?
Thanks!
It's got nothing to do with preout voltage.
It's considered better if a head units preouts run at a higher voltage as the more current they carry the less RF noise they tend to pick up. But it's not the cause of your problem.
Check all you grounds again, and try different locations. Try a new ariel cable etc etc all the basics.
If all else fails try another headunits, yours could simply be faulty...
Posted 05 December 2012 - 07:47 PM
Posted 05 December 2012 - 07:56 PM
Posted 05 December 2012 - 08:39 PM
well thats the same headunit as mine, and ive got the same problem, ill try out what ive said on the weekend and get back to you but its the only solution i can think of after trying many things and researching it deeply
I just don't undestand how you have made the link between RF interference coming in to the FM receiver and the voltage of the preouts?
