Indicator Fuse Keeps (C6) Keeps Blowing When Turning Right? Please Help!
11 replies to this topic
#1 fattail95
fattail95
  • 873 posts
Posted 21 November 2012 - 06:20 PM
Hi there guys,
This problem is driving me mad!! The other day, the indicator fuse started blowing all the time, but now it only blows when you turn the wheel right, any ideas?? Its an MPI
Ben
#2 charie t
charie t
  • 3,153 posts
Posted 22 November 2012 - 12:32 AM
When you say turn right do you mean turn the wheel or indicate right?
#3 Vonski
Vonski
  • 11 posts
Posted 27 November 2012 - 12:06 AM
Sounds like you have a short circuit to positive on one of the right hand indicators.
Try taking ONE of the right hand indicator bulbs out at a time and indicating right. When you can indicate without blowing the fuse then you know on which bulb circuit you have the short. Then trace the wires going to that bulb and look for any damage to the wires caused by sharp edges or chaffing.
#4 toplessmini
toplessmini
  • 492 posts
  • Local Club: none on the island....
Posted 27 November 2012 - 09:22 PM
Did you have any luck with this?
My MPI blows the fuse as soon as I switch the ignition on, I need to get out there with the multimeter and sort it out............... >_<
#5 fattail95
fattail95
  • 873 posts
Posted 28 November 2012 - 05:35 PM
Reporting back! Sorry for the delay!
Now whenever I turn on the ignition C6 blows, killing the reversing light, brake lights and indicators. Hazards work perfect, but sometimes the switch is temperamental...
Any ideas?
Edited by fattail95, 28 November 2012 - 05:35 PM.
#6 charie t
charie t
  • 3,153 posts
Posted 28 November 2012 - 06:08 PM
My money is on the earth point below the wiper motor on both your cars
#7 fattail95
fattail95
  • 873 posts
Posted 28 November 2012 - 06:33 PM
Both my cars? All these faults are with the same one I'm afraid xD So do you simply remove the wiper motor and look for what?
#8 charie t
charie t
  • 3,153 posts
Posted 28 November 2012 - 07:13 PM
topless mini has the same issue as you, as posted above
The wiper motor is nearest component i could think of.
There is a multiblock connector on the bulkhead crossmember. The spade terminals are usual issue
#9 fattail95
fattail95
  • 873 posts
Posted 28 November 2012 - 08:26 PM
Surely if the fuse is blowing whenever the ignition is switched on a live is going to ground?
#10 jamesmpi
jamesmpi
  • 1,940 posts
Posted 28 November 2012 - 09:51 PM
Have you looked at this?
http://www.theminifo...attach_id=68240
#11 toplessmini
toplessmini
  • 492 posts
Posted 28 November 2012 - 11:56 PM
Yep I have a print out of the indicator circuit from the above link and also have my Haynes wich covers upto 01/X reg Mini's.
My problem came about on the way home from my MOT. I remember reading some where that the Hazard switch might have a part to play in all this.
I'm going to get the multi meter out and disconnect each part from the circuit one by one.............
#12 fattail95
fattail95
  • 873 posts
Posted 29 November 2012 - 07:36 AM
Yeah my hazard warning light is being temperamental at the moment...
