Steering Rack Question.... Whats The Difference
Posted 22 November 2012 - 07:29 AM
Ill be renewing the steering rack soon and wondered what the difference is between racks for sportspack and non sportspack.
Is it just the amount of turns from lock to lock or is it something else?
The 1990 city im restoring will be fitted with sportspack arches when complete and wondered if this has any relevence to the type of rack with regards rubbing or fouling when in full lock.
Alternatively, is there such a thing as a repair kit for the mini steering rack?
The one i have isnt too bad, just tatty and in need of some stripping and cleaning.
Thanks in advance.
Posted 22 November 2012 - 07:42 AM
Max
Edited by minimaxie, 22 November 2012 - 07:44 AM.
Posted 22 November 2012 - 07:51 AM
Hello folks,
Thanks in advance.
I can't answer the first question!
But the innards are no longer available - you can either buy a reconditioned rack or just clean it up if it is okay.
I took the gaiters off mine, gave everything a good clean and re-grease, new gaiters, track rod ends and pint job - looks like new!
Posted 22 November 2012 - 07:52 AM
Ill be running 12" deep dish super lights with a tyre profile of 60, so would you say they would be ok?
Its got new rubber cones so the suspension is back to original height etc.
Id assume the full lock turning circle is the same for both types of rack?
Posted 22 November 2012 - 08:22 AM
Well generally, if you have anything wider than 5inch, it will usually require some minor trimming around the arch line on the body. There's templates floating around on here on how much to cut off, but I don't know where they're under. If you have a Sportspack rack it could reduce the scrubbing. But as you say if you have new suspension parts and cones then that will help too.
I'm not too sure on that one pal, will need to ask the pros on here, sorry I can't be anymore help
Edited by minimaxie, 22 November 2012 - 08:46 AM.
Posted 22 November 2012 - 02:32 PM
I do own a lathe, which helped. I just made a new bushing from nylon and went "yeah, that will work". There is exactly 1 bushing in the whole rack, rest is sprung metal to metal holding.
Posted 22 November 2012 - 02:35 PM
All later standard steering racks are designed as non-serviceable.
Posted 22 November 2012 - 04:41 PM
Break out a new wire brush and some smoothrite silver plus some gaitors for the existing rack, should do the trick.
