Car Stalls, Found Broken Hose.
5 replies to this topic
#1 CharlesK
CharlesK
  • 59 posts
Posted 22 November 2012 - 01:52 PM
Hi, my car has been stalling when I stop at a light or when i press the clutch while rolling. i can keep it going by using the choke. once i'm at a stand still i can turn the choke off and the car runs idle. i checked the hose going to the distributor, it's not that. i then checked the other connections and i found a broken hose. I'm not sure what it's supposed to do. i added the picture of the hose and the points where they were connected. the hose was broken clean in half and had a rip in it. has me driving it caused any damage? What does it do? is this why my car is stalling?
Thanks.
this is where it connected to the carb
Attached File  IMG_20121122_142918.jpg   59.3K   16 downloads
this is where the hose connected to
Attached File  IMG_20121122_142942.jpg   51.66K   7 downloads
the broken hose
Attached File  IMG_20121122_143050.jpg   61.99K   12 downloads
#2 Ethel
  • 26,580 posts
Posted 22 November 2012 - 02:17 PM
Crankcase ventilation, it sucks fumes out of the sump and burns them in the engine, the reduced pressure also helps prevent oil leaking out. Replace it (any motor factors- but make sure it's oil/fuel hose), temporarily you can just block the connection on the carb to stop it letting air in and making the mixture too weak.
#3 CharlesK
CharlesK
  • 59 posts
Posted 22 November 2012 - 02:29 PM
Could that extra air being sucked in be the reason for the engine stalling or would that be something else? Thanks anyway, i'll make sure to reconnect it.
#4 Big_Adam
Big_Adam
  • 7,435 posts
What Ethel says. Also if you're in a right pickle, you can use just garden hose pipe. Don't expect it to last long, but if you just need to get home its another option. Or just get a BIC pen, take the guts out, chomp the end off and use it to make a bridge in the broken pipe.
Edit
The stalling is due to the engine running MASSIVELY lean.
Edited by Big_Adam, 22 November 2012 - 02:30 PM.
#5 CharlesK
CharlesK
  • 59 posts
Posted 22 November 2012 - 03:50 PM
Edit
Thanks guys. I replaced the hose and it works great again. It no longer stalls and runs without choke having to be on
#6 Ethel
  • 26,580 posts
Posted 22 November 2012 - 03:59 PM
Just a bit of extra info: as with all air leaks, the effect is greatest when the throttle is nearly closed because the more open the throttle is the greater proportion of air will go through it to mix with petrol normally. Useful to know for diagnosis and if you are compensating with the choke.
