Rover Mini Cooper Mpi Mot Problems Passing
Posted 24 November 2012 - 10:27 AM
Posted 24 November 2012 - 10:33 AM
Posted 24 November 2012 - 11:25 AM
Posted 24 November 2012 - 01:31 PM
Posted 24 November 2012 - 01:54 PM
The first thing I always check is compression, then spark at all cylinders, ignition timing. If all these are good move onto checking the fuel/combustion using a colortune. Pin it down.
Colortune are great and allow you to pin down a specific cylinder with a problem which can give you a good idea where to start.
J
Posted 24 November 2012 - 02:18 PM
I.e a spirited drive for half hour ish before the MOT so it's nice and warm and all the cobwebs are blown out :)
However I dont really know but someone with knowledge might be able to tell me if this is a load of tosh?? :)
Posted 24 November 2012 - 02:23 PM
Im not sure but I know that people with mgfs take them for an Italian tune up before MOTs
The cat needs to be up to operating temp but this does not matter anymore as the current MOT test requires the tester to warm up the engine oil for the gas test anyway.
Posted 24 November 2012 - 02:27 PM
Ignore me then
Posted 24 November 2012 - 02:53 PM
Posted 24 November 2012 - 04:47 PM
hi the compressions are fine it had a new head about six months ago from mini speed the tappets are ok new plugs leads and an oil change.
the hydrocarbons are reading 6268 and the co is 3.940.
I have also taken it for a long run before the emissions test each time.
I did change the plug leads around and this sent the hydrocarbons off the scale.
I have been told that the Air Control Valve on Inlet Manifold could be not working. The garage said that it is supposed to close up once the vehicle is warm which lowers the air that enters the manifold I don't think mine dose.
Posted 24 November 2012 - 06:08 PM
Posted 24 November 2012 - 06:30 PM
Ive had seven carb models and one SPI and I never had any problems as I have with My MPI
Ive been to my garage five times now and put it on the emisions test soon I will be on their Christmas card list.
The wife wants to sell the Mini
Posted 24 November 2012 - 06:31 PM
For an Mpi that is way off the scale... as the pass is 200ppm HC and 0.3% CO
in fact for any car that's way off the scale !
Posted 24 November 2012 - 07:45 PM
Posted 24 November 2012 - 08:25 PM
last year it failed on emisions before I owned it they changed the Lambda sensor and the water temp sensor also the cat and had the ecu repaird.
I am going to check out the air control valve as a few people have said that.
do anybody know if it sucks in less air or closes all together when the car reaches operating temp. if so mine dont it just stays the same.
