Hole In Drivers Side Footwell And Water Getting In
Posted 24 November 2012 - 06:18 PM
driving through the monsoon today I felt my foot getting wet. The first problem is how do I stop the water leaking in through the drivers and passengers air vents or is it just something normal?
The second question is at the drivers side footwell there is a circular hole big enough to get a hand into. Its a machined hole as I can feel it smooth so seems it should be there. its near the accelerator pedal on the inner wing. Is it supposed to be open or is something supposed to plug into it?
Posted 24 November 2012 - 06:23 PM
This is a common place for minis to rot
Posted 24 November 2012 - 06:29 PM
Posted 24 November 2012 - 06:31 PM
Posted 24 November 2012 - 10:14 PM
You can see the engine bay black piece in the bottom left corner (random google image) The duct follows the blue line into wheel well, then into the driver's side
Posted 24 November 2012 - 10:34 PM
It can be a pig to fit as well.
Posted 24 November 2012 - 11:05 PM
Posted 24 November 2012 - 11:08 PM
Posted 24 November 2012 - 11:10 PM
Posted 24 November 2012 - 11:11 PM
Also if you have water coming in via the fresh air vent then there is an issue with either the seal or its also the ducting has disconnected from there as well.
Posted 24 November 2012 - 11:15 PM
Posted 25 November 2012 - 08:00 AM
But if you heater works happily, I guess you could just blank it off. It's nice down here in summer as I usually drive barefoot and it's a nice foot-air-con, but in winter is a cold draft.
Sonikk4 - where would the heater get it's intake air from if he doesn't have this duct? From another duct on the left? Or would it just draw from inside the cabin?
Posted 25 November 2012 - 08:03 AM
Posted 25 November 2012 - 11:10 AM
thanks for the help!
Posted 25 November 2012 - 04:45 PM
