Rusty Roof - When Is Too Much Rot Too Much.
13 replies to this topic
#1 sixtyeight
sixtyeight
  • 630 posts
  • Local Club: forums.minidriver.com.au
Posted 26 November 2012 - 11:24 AM
So I have just purchased a mini and it has a rusty roof (amongst other parts). As per the pic below, this is the worst patch (about the size of a fist), slap bang in the middle of the roof. This has been wire brushed back, and deoxidized to convert the rust. Would this be ok to skim fill over and paint? Or is the rot too deep and will continue - it is fairly badly pitted? I
d rather not replace the roof, but do happen to have a donor car with a near perfect roof...
Attached File  WP_000033.jpg   51.78K   39 downloads
Tim.
#2 waddle
waddle
  • 536 posts
Posted 26 November 2012 - 01:48 PM
can it not be patched ?
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,044 posts
Posted 26 November 2012 - 03:52 PM
You could but you would end up with a big dip in the roof from the heat distortion.
#4 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 26 November 2012 - 04:12 PM
the best thing when repairing things is to get it back to bare metal, ive never done anything like this on a roof but maybe try sanding it down to bare metal (PLEASE GET SOME BETTER ADVISE before you do this as ive never done it before) then skim the filler over, prime it and paint
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 26 November 2012 - 04:14 PM
this is now on the road after sitting in that lake for 30 years
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,095 posts
  • Name: Neil
Posted 26 November 2012 - 06:18 PM
It does look like the whole roof needs stripping back to bare metal. When you have done that then you can see if there are any other patches / areas that may be an issue.
The odds on cutting that out and not rippling the roof will be high. Do not fill over it as it will return plus if its badly pitted then the roof skin will be that much thinner there as well.
#7 Vulcan
Vulcan
  • 130 posts
Posted 26 November 2012 - 06:22 PM
Take it back to bare metal and see what state the steel's in. It may not be too bad.
Welding in a new piece, should it be properly holed is possible, just friggin' hard. Not just in terms of welding skill but you'll also need to remove the headliner and most of the interior.
#8 sixtyeight
sixtyeight
  • 630 posts
Posted 26 November 2012 - 07:37 PM
the whole car will be stripped back to bare metal - but what I was curious about are the bad areas like those above. I think that where it is pitted like that is too thin - there are a lot of places on the roof like this, albeit smaller, but I think the whole roof is going to have to be replaced. There is no way I am patching/welding a roof as I know it will warp and never look right!
#9 MiniLuke
MiniLuke
  • 1,205 posts
Posted 26 November 2012 - 07:40 PM
Ask this guy for the roof.
http://www.theminifo...63#entry2647763
#10 sixtyeight
sixtyeight
  • 630 posts
Posted 26 November 2012 - 07:41 PM
so new roof it is... there is a lot of rot on the roof, just not as large as the spot photographed. it never goes right through the metal, but it will just come back I think.
I was going to replace the roof by cutting the A, B and C pillars, and staggering the A and B pillars inside and outsides, and joining the C pillar with an internal plate plug welded, then seam welding the join.
#11 sixtyeight
sixtyeight
  • 630 posts
Posted 26 November 2012 - 07:42 PM
shipping would be a killer - I live in Australia. I have a spare roof/donor car already anyways :)
#12 MiniLuke
MiniLuke
  • 1,205 posts
Posted 26 November 2012 - 07:44 PM
LOL didn't realise. Thought it didn't rain down there!
#13 sixtyeight
sixtyeight
  • 630 posts
Posted 26 November 2012 - 08:21 PM
Attached File  WP_000036.jpg   61.65K   9 downloads
Attached File  WP_000037.jpg   68.97K   5 downloads
was meant to be a dry 'country car' but I was wrong!
Edited by sixtyeight, 26 November 2012 - 08:22 PM.
#14 tiger99
tiger99
  • 8,584 posts
Posted 27 November 2012 - 07:49 PM
Why are you even thinking about cutting pillars, which immediately gets you into structural problems and having to seam weld "invisibly"? Why just not drill out the spot welds and swap roof skins? Much less disruptive.
