Water getting into sills?
13 replies to this topic
#1 Tony1003
Tony1003
  • 142 posts
Posted 31 March 2006 - 06:18 PM
:( Can anyone give me some idea how water would be gettin into my sills i need to solve the proplem due to me getting a nasty rust hole on the floor of my car and also water leaking into my footwell :'( Any suggestions will be most welcome guys n gals ;D
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 31 March 2006 - 07:12 PM
are there any holes in the inner wheel arch ? ;D
where the wheels kick up all the spray
#3 Tony1003
Tony1003
  • 142 posts
Posted 31 March 2006 - 10:06 PM
cant see any bungle its when its stood in the rain or i wash it :(
#4 gsms
gsms
  • 2,285 posts
Posted 31 March 2006 - 10:17 PM
Have you checked out the lower part of the windscreen seal?
#5 pikey7
pikey7
  • 3,824 posts
Posted 31 March 2006 - 10:42 PM
possibly door seals too.
To check, sit in the car with a few sheets of kitchen roll. hold a bit against the seal, and have a friend (or family member!) pour or hose (depending on the bans in your area!) water on that area from the outside. If you have a leak, it'll move through the leak and soak the paper. you can then change the offending seal.
Have you got a pic of the area where the rust is? it could help us narrow it down.
#6 gsms
gsms
  • 2,285 posts
Posted 31 March 2006 - 10:49 PM
There's also a slight chance that's its actually coolant leaking into your footwell from the hoses attached to the heater.
#7 Tony1003
Tony1003
  • 142 posts
Posted 31 March 2006 - 11:04 PM
I did have a leak from them i sorted that the leak now it comin from the sill if i make sense where the floor meets the side of the car under the door, water is coming from in there, some how water is getting inside the sill n then through the hole ;D
#8 pikey7
pikey7
  • 3,824 posts
Posted 31 March 2006 - 11:12 PM
so the hole is in the vertical surface between door and floor?
#9 Tony1003
Tony1003
  • 142 posts
Posted 31 March 2006 - 11:24 PM
You got it pikey n thats where the water is coming from
#10 pikey7
pikey7
  • 3,824 posts
Posted 31 March 2006 - 11:31 PM
the inside of the sill will never be watertight. Mine's in bits because that whole area was one big hole, and it looks as though the jacking point is not sealed at all, so it's probably coming in there. Though just to check, get on your knees and have a good look under the side of the car along the whole length. you may have other holes (I hope not!)
You can patch the hole by welding a small piece over it, and then waxoyl inside the sill. I suspect that if there is a hole in it now, then the rest of the panel isn't going to be very nice, but it's not a quick and easy job to change. Eventually you'll need new inner sills.
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 April 2006 - 06:56 AM
Of course if it has genuine sills there would be drain holes... so I assume you have oversills !
#12 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 01 April 2006 - 07:11 AM
have a look at the seals for the door stop, by the interior light switch on the a post, if its perished at the top the water could come in through there, down the a post into the sill then out of your hole, ad a new seal and no longer leaking
#13 Tony1003
Tony1003
  • 142 posts
Posted 01 April 2006 - 04:46 PM
Yeh it has one oversill i have only had the car a couple of months tryin to get it all sorted :( its not in bad condition for its age though ;D
Cheers will have a look tonight
#14 NateDogg2909
NateDogg2909
  • 188 posts
  • Local Club: NottsAboutMinis
Posted 03 April 2006 - 05:18 PM
This could be a area you could check.
I noticed that i had water on the door seal at the bottom after it rained hard, check the seal no water there. So where was it coming from?
I had to replace my winder mech cus the glass clamp at the bottom buggared off and disintigrated! After that i noticed that the door cards where bowing so water + wood = bowing.
The water was leaking from the winder mech where the putty wasn't quite all there, moved some around a bit and its seems to have helped.
Just have a look wont take you 20mins.
Nate.
