Hi do anybody know how you reset the ECU on a MPI mini
I have been told you just disconect the battery is this correct.
Ecu Reset
aspicer0
, Nov 27 2012 11:49 AM
4 replies to this topic
Posted 27 November 2012 - 11:49 AM
Posted 27 November 2012 - 11:54 AM
I believe so, if you disconnect the battery for half an hour or so, it should reset the ECU
Posted 27 November 2012 - 07:34 PM
You need to unplug it for a minute thats all.
Plug it back in, then press the lock button 5 times, then unlock.
You will now be able to use the car again.
Posted 27 November 2012 - 08:31 PM
Why do you need to reset the ecu?
Posted 28 November 2012 - 08:44 AM
I have been advised to have it reset after some over fueling problems which is causing the car to fail the mot
I have changed a few sensors.
