A Questions Jumble
Posted 27 November 2012 - 01:05 PM
Should there be any illumination in the 4 rocker switches at all? Currently only the speedo lights up when the sidelights come on.
The speedo reads quite a bit below the actual speed when checked against a sat nav/other car - would this likely be due to the rolling radius of the 13" wheels over whatever the car came with? How can I fix this?
The fuel guage doesn't work it always reads empty. If I connect together the wires off the sender unit on the tank it reads full, so I'm thinking the sender may have seized having sat for 10 years. If I let the tank run to empty can I pop the sender out to free it up without mashing the gasket, or do I only do the job with a new gasket waiting in the wings?
I dont seem to be able to find bolt-in cross braces for the roll cage in the intenet - do they exist or am I best fabricating one and welding it in?
Cheers!!
Posted 27 November 2012 - 01:56 PM
only when they are switched on
unless your 13's were fitted from new your speedo will be out, you can change the gearing on the speedo drive but it's not something i have done before to help with
i would replace the sender and gasket
do you know who made the cage ?
Posted 27 November 2012 - 03:37 PM
It's bolt together, inch and three eighths guage.
Posted 27 November 2012 - 04:00 PM
Posted 27 November 2012 - 04:09 PM
Posted 27 November 2012 - 04:11 PM
Posted 27 November 2012 - 04:45 PM
If you want illuminated switches there is a kit available (a bit pricey) or you can have a go yourself, the illumination has it's own mini spade terminals on each switch.
Tyres shouldn't make a lot of difference to the speedo, first check the mileometer against a known distance on the road. If it's right it's a faulty speedo. If not, you have some extra info to guess what diff ratio you have.
http://www.guess-wor.../Tech/ratio.htm will help too.
Posted 27 November 2012 - 05:22 PM
Brown with brown stripes?
Yeah - that was ambiguous!!
It was just a thought with the lit up switches - thought there might be a quick fix. I'm getting better at knowing what's what by feel alone in the dark, and hardly ever put the hazard lights on instead of the rear demist! In time I'll swap them out for metal toggle switches anyway.
I guess an 86 city came with 10 inch wheels? What profile tyre did it have? Would be interesting to see what the difference in rolling diameter is between that and the 13's and low profiles that are on there now. 30 on the speedo is pretty much 40 in the real world. 50 is nearly 70... it seems to be a sliding scale.
Posted 27 November 2012 - 10:20 PM
Posted 28 November 2012 - 11:48 AM
Posted 28 November 2012 - 01:27 PM
Posted 28 November 2012 - 03:22 PM
The Landy was out by a country mile, but the Mini was pretty much acurate still.
So somehow, in the 10 years the car was sitting unused, maybe the speedo has developed a fault?
Edited by Dope, 28 November 2012 - 03:28 PM.
