Replacing Valve Guides
12 replies to this topic
#1 foggy
foggy
  • 215 posts
Posted 27 November 2012 - 03:14 PM
Hi all.just a quick one...can anyone tell me if you can just press out valve guides and press a new set in? I am talking about both sets being steel
#2 Sir Yun
Sir Yun
  • 15 posts
Posted 27 November 2012 - 04:00 PM
in short.
yes.
and it is cast iron not steel by the way
#3 freshairmini
freshairmini
  • 1,718 posts
Posted 27 November 2012 - 04:02 PM
http://www.theminifo...g-valve-guides/
BOOM! This thread pretty much covers the answer.
#4 foggy
foggy
  • 215 posts
Posted 28 November 2012 - 09:06 AM
Thanks guys...although it is steel valve guides you can buy...didnt realise tge standard guides cast iron
Edited by foggy, 28 November 2012 - 09:11 AM.
#5 Cooperman
  • 23,513 posts
Posted 28 November 2012 - 11:39 AM
Just off to the workshop to press in a new set in a 940 head shortly. Waiting for it to warm up in there a bit first.
#6 Carlos W
Carlos W
  • 10,115 posts
Posted 28 November 2012 - 11:58 AM
Do you want to do mine?
#7 Cooperman
  • 23,513 posts
Posted 28 November 2012 - 03:30 PM
It took me about 15 minutes to press the new ones in and set them to the right height. The old ones were out already as it is a head I've been doing some gas-flowing on. Just got to get the seats cut, the valves lapped in, combustion chambers measured and head skimmed for ideal compression ratio.
#8 Scoop77
Scoop77
  • 508 posts
Posted 28 November 2012 - 04:03 PM
What ratio will you be taking it up to?
#9 Cooperman
  • 23,513 posts
Posted 28 November 2012 - 04:17 PM
It's not for me so I need the owner to tell me what he wants it to be. I shall advise between 10:1 & 10.2:1 but it's his decision.
#10 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 28 November 2012 - 05:20 PM
Do you have your own press or did/do you hammer them in with a suitable drift?
#11 Cooperman
  • 23,513 posts
Posted 28 November 2012 - 05:33 PM
I always use my large vice to press them in. Works fine so long as you dont put them in too far.
To get the old ones out I have a 1/4" bolt with the head ground circular so that it is slightly less than the OD of the guide, then I punch the guides out using the bolt as a mandrel.
#12 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 28 November 2012 - 07:05 PM
I was curious about how you were pressing them. I replaced the guides on my 2-L Triumph engine last year. I have a WW-II era milling machine and I used its knee to press the guides in and out. It would have been smarter and easier if I had taken the head to work and used the hydraulic press.
For what it's worth at this point, to control the insertion depth I made a stop collar that went around the outside diameter of the guide. That prevented me from pressing the guides in too far. I am sure you could do the same for an A-series head.
#13 Cooperman
  • 23,513 posts
Posted 28 November 2012 - 07:35 PM
I put no.1 guide in first, then no.8. When they are exactly right I fit the others in turn using a straight edge between 1 & 8 to ensure that all go in the correct amount, +/- about 0.005". It's always worked OK.
