Heater For Your Garage
Posted 28 November 2012 - 09:56 PM
from looking at clarke heater like this one my garage is 12ft by 12ft
what type of heaters do you guys have
cherrs dave
http://www.clarkedis...&product_id=140
Posted 28 November 2012 - 09:59 PM
Posted 28 November 2012 - 10:00 PM
stop drafts etc
we have a tiny gas space heater which we use for small spaces, in our container for example 20ft x 8ft. it is quite good on gas compared to our bigger one.
Jordie
Posted 28 November 2012 - 10:10 PM
As a heating engineer i would advise against using this type of heater in such a small area because this type of heater releases the products of combustion into the same area as it does not have a flue. The manufacturer will have enclosed specific instructions as to its safe use,ie in areas with adequate ventilation and a minimum area.Hi all i am looking for a gas space heater for the garage for the winter
cherrs dave
A good electric oil filled or fan type heater would be a much safer option. I use one with a plug-in timer so my garage is warm when i want to work in there and also it switches off if i forget to turn it off. Forget about gas fired heaters!!!!!!!
Posted 28 November 2012 - 10:13 PM
have not used it since 2009. new for sure it wouldnt work.
fired up first go
heats my garage up in no time
http://www.ebay.co.u...d6ef5377&_uhb=1
6m long 3 meters wide
like this one
Posted 28 November 2012 - 10:14 PM
I just have a second hand indoor portable butane gas heater, it's cheap and cheerful, but does the job and only cost me £10! Plus they're an absolute godsend to have to hand if your central heating ever breaks down in the middle of winter.
agree
Posted 28 November 2012 - 10:15 PM
Posted 28 November 2012 - 10:18 PM
Posted 28 November 2012 - 10:51 PM
Posted 29 November 2012 - 09:28 AM
Posted 29 November 2012 - 09:30 AM
I've got a Clarke barrel stove because it came very cheap - if it hadn't I would have converted a gas bottle. My garage/workshop is around 40 feet long by 20 feet wide. I'm spoiled but still manage to run out of space.
Iain
Posted 29 November 2012 - 09:31 AM
Posted 29 November 2012 - 04:13 PM
I'm fortunate I have remote heating, waste heat from the local powerplant. But when I had a broken water pipe, I used electric for a month. Big mistake.
