Steering Rack Limiters
5 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 28 November 2012 - 10:18 PM
Hi chaps I'm fitting sports pack arches and possibly 13/7 super lights or similar I've read through some post about cutting the wings and the templates needed however a few people mention the steering rack limiters where do you get these from as cant find them in minispares
Thanks chaps.
#2 Tahiti Joe
Tahiti Joe
  • 663 posts
Posted 28 November 2012 - 10:20 PM
Made by KAD i believe, sold by a few people.... Heres a linky...
http://www.minisport...KAD1012230.html :D
#3 Algordo1100
Algordo1100
  • 774 posts
Posted 28 November 2012 - 10:33 PM
If you fit some of Minitastic's longer steering arms it will have the same effect by not allowing the wheels to pivot as much (bigger turning circle). The added bonus is your steering will be lighter which may be useful with such big wheels fitted. I havn't used Minitastic's steering arms myself so I can't vouch for them. Just an idea.
http://www.minitastic.co.uk/home1.htm Click on steering arms.
Al
Edited by Algordo1100, 28 November 2012 - 10:35 PM.
#4 leepol83
leepol83
  • 1,744 posts
Posted 01 December 2012 - 06:50 PM
That's great thanks chaps can I fit the limiters without removing the rack where abouts do you put them.
Thanks guys
#5 tiger99
tiger99
  • 8,584 posts
Posted 02 December 2012 - 04:55 PM
You can, with some slight difficulty, fit them without removing the rack. If you can change a rack gaiter in situ, you already have the skill, patience and almost all the knowledge to do it. Basically, undo inner end of gaiter and pull back, fit limiter, refit gaiter, and if necessary replenish lubricant. Quicker than partially dropping the subframe to get the rack out.
There is, or were, more than one design of limiter, some are just plastic (nylon?) which is perfectly adequate, others metal, and how they are fitted varies, but will be obvious once you have them in your hand. Basically they clip around the rack, behind the inner ball joints, or into the ends of the rack outer tube, so that they act to prevent the ball joints retracting hard against the outer tube on full lock.
Edited by tiger99, 02 December 2012 - 04:56 PM.
#6 leepol83
leepol83
  • 1,744 posts
Posted 02 December 2012 - 08:38 PM
Hi matey thank you for the help that sounds quiet strait forward I shall get some and pop them in if only it was that easy ha ha! Thanks for the help mate you're a star.
