Reverse Gear Problems
25 replies to this topic
#1 min ritz ryan
min ritz ryan
  • 251 posts
  • Local Club: Skidmark Mini Owners Club
Posted 01 December 2012 - 12:29 AM
Hi all. I was wondering if any one could help me, ive had provlems selecting first and second gear, but ive resolved that by installing a new gear selector, but after fixing the problem I now can not select reverse. Does anyone know why that may be and how I could resolve the problem?
#2 SA MINI
SA MINI
    Previously known as shaunarmes.
  • 1,001 posts
  • Local Club: yet to join HAMOC
Posted 01 December 2012 - 12:51 AM
Hi. Have you got a manual or automatic transition ?
#3 min ritz ryan
min ritz ryan
  • 251 posts
Posted 01 December 2012 - 09:51 AM
Manual transmission.
It was working fine before I changed the gear selector
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 01 December 2012 - 10:51 AM
Put the old gear selector back on see if it improves things.
#5 min ritz ryan
min ritz ryan
  • 251 posts
Posted 01 December 2012 - 11:02 AM
I would do but then I lose 1st and 2nd as the hole where the roll pin sits is too big/ wide and the selector pushes away from the diff
#6 tiger99
tiger99
  • 8,584 posts
Posted 01 December 2012 - 12:00 PM
If the hole is too big, you need a new coupling 42H 1116 and two new roll pins RPS 1416. Check the mechanism for other bits that are worn or sloppy too, and that the steady rod is ok and its rubber bush 13H 7288 not worn. Diagram here:
http://www.somerford...age=page&id=152
#7 min ritz ryan
min ritz ryan
  • 251 posts
Posted 03 December 2012 - 06:31 PM
Well the hole isn'to too big now, as I have the new gear selector on and the roll pins sit fine and there isnt any unusual movement in it towhat there was, I just dont understand why it wont select reverse now, as it was fine before
#8 tiger99
tiger99
  • 8,584 posts
Posted 04 December 2012 - 01:32 PM
It is possible that the bottom cover of the selector, which incorporates the reverse detent, is fitted backwards. Failing that, is there any sign that the operating rod or the steady rod are twisted?
Edited by tiger99, 04 December 2012 - 01:34 PM.
#9 min ritz ryan
min ritz ryan
  • 251 posts
Posted 06 December 2012 - 11:54 AM
No sign of rod being twisted.
Is there an adjustment on the gear linkage, as a friend has suggested to drop it in 3rd and try adjusting it? :S
#10 tiger99
tiger99
  • 8,584 posts
Posted 06 December 2012 - 01:11 PM
There is no adjustment. If it is wrong, it is twisted or worn somewhere, but have you actually checked that the bottom cover, which forms the reverse detent, is the correct way round? Try selecting the gears with it removed.
#11 min ritz ryan
min ritz ryan
  • 251 posts
Posted 06 December 2012 - 07:02 PM
Oh right, okay. No, not yet but ill check it later and let you know how I get on. Thabks
#12 min ritz ryan
min ritz ryan
  • 251 posts
Posted 06 December 2012 - 09:51 PM
Okay, good news is I have reverse back, but now I have lost 1st and 2nd!! Any ideas what I can do from here, as I have taken the plate off and turmed it around to the correct place :S
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 06 December 2012 - 10:57 PM
you know you normally need to lift the gearstick to engage reverse....
try lifting the gearstick and see if 1st and 2nd return
#14 min ritz ryan
min ritz ryan
  • 251 posts
Posted 06 December 2012 - 11:01 PM
Tried that already, and no luck
#15 min ritz ryan
min ritz ryan
  • 251 posts
Posted 07 December 2012 - 11:10 AM
Could it be an idea to fabricate a new plate up, as I noticed a bar inside of it and im guessing its catching that
