1340 And 1380 Engines. What Is The Difference?
25 replies to this topic
#1 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 01 December 2012 - 05:15 PM
Other than the obvious what is the difference between 1340 and 1380cc engines- bore or stroke?
thanks
#2 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 01 December 2012 - 05:28 PM
Bore
a 1380 = 73.5mm bore
a 1340 = 72.5mm bore
Both with a 81.3mm stroke
Edited by mini_mad69, 01 December 2012 - 05:33 PM.
#3 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 01 December 2012 - 05:36 PM
Interesting,
It has 73.5 pistons but the block is marked 1340?
Do you know how to identify a turbo block?
#4 mini_mad69
mini_mad69
  • 5,417 posts
Posted 01 December 2012 - 05:42 PM
I think there might be a number or two different one them. But primarily turbo blocks are the same as any other 1275 block. It's the bits attatched to the turbo motors that are different.
i don't know why it's marked 1340. Possibly bored out to 1340, worn out and then bored again but the number remained?
#5 Tupers
Tupers
  • 4,156 posts
Posted 01 December 2012 - 05:48 PM
A turbo block should be the same as any other 1275 from the same year.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 December 2012 - 06:03 PM
A true 1340 is a 73.5mm bore with a short stroke 79mm crank...
What most people call a 1340 nowadays is actually a 1330 +0.060 bore on a standard crank.
Never heard of 72.5mm pistons ???
#7 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 01 December 2012 - 07:59 PM
Thats what i recallected about the old skool 1340, it rev'ed harder than a 1380.
Where/what can i get a 79mm crank from?
Yep typo 73.5 hepolite pistons
#8 Tupers
Tupers
  • 4,156 posts
Posted 01 December 2012 - 08:03 PM
Is a 79MM stroke crank not a standard one that's been offset on the big end to take S rods?
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 December 2012 - 08:41 PM
It is
#10 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 02 December 2012 - 08:59 AM
So it's just a crank grind then? If the rods are on the pistons they must be S ? I shall get some numbers.
#11 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 02 December 2012 - 11:06 AM
Rods are 12G 4114/5 so that does not help.
I am presuming that the block is decked for a 1340?
#12 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 02 December 2012 - 12:09 PM
It's an offset crank grind yeah. My old man used to run one in his GT back in the 90s and it was a revvy little thing..
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 02 December 2012 - 12:33 PM
Rods are 1.75" big ends so not offset ground crank, it's a 1380.
#14 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 02 December 2012 - 01:02 PM
I meant that the 1340 is an offset ground crank....not this one.
#15 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 02 December 2012 - 02:28 PM
Ther is no crank fitted,
Any ideas of the deck height for both blocks?
