Do I Need To Drill A Hole In New Thermostat?
9 replies to this topic
#1 ricekikr
ricekikr
  • 173 posts
Posted 04 December 2012 - 03:02 PM
New thermostat doesn't have a hole on the flange, should it be drilled or left alone? What size drill bit?
#2 JonnyBMX
JonnyBMX
  • 865 posts
  • Local Club: Rebels
Posted 04 December 2012 - 03:05 PM
by this do you mean to holes that are used to retain it onto the head?
#3 ricekikr
ricekikr
  • 173 posts
Posted 04 December 2012 - 03:28 PM
I mean the bleed holes on the thermostat itself. Stock has one bleed hole. Something like this.
#4 tiger99
tiger99
  • 8,584 posts
Posted 04 December 2012 - 03:30 PM
I think he means the hole in the thermostat itself which allows some water to flow before it opens, and incidentally does assist with getting air out of the system when you first fill it. Some people used to drill them 1/4 inch, others 5/16". It is not all that critical.
Edit - almost simultaneous post, and those holes look perfectly ok.
Edited by tiger99, 04 December 2012 - 03:31 PM.
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 04 December 2012 - 03:51 PM
does the head have a bypass hose fitted ?
#6 ricekikr
ricekikr
  • 173 posts
Posted 04 December 2012 - 03:56 PM
Got the pic from Google for a different car I think.
Yup. It's the hose connected on top of the front part of the head on the tranny side right?
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 04 December 2012 - 04:01 PM
about an inch long and goes between the water pump and the head
#8 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 04 December 2012 - 05:39 PM
Those holes are not standard. We used to drill them if the car was running hot to increase the flow.
Now you would just buy a better radiator with a more cores but back in the days before the internet we only had standard rads.
#9 Cooperman
  • 23,340 posts
Posted 04 December 2012 - 08:10 PM
If running a engine with the heater valve at the clutch end of the engine and no by-pass hose, then it is good to drill a few holes in the thermostat flange to permit flow during warm-up. If a by-pass hose is fitted then the holes are not necessary.
The standard radiator should be adequate for all except, perhaps, full-race engines. If a Mini overheats then there is a problem somewhere in the cooling system.
#10 racingbob
racingbob
  • 3,061 posts
Posted 04 December 2012 - 08:39 PM
would it not take longer to warm engine up and make engine run cooler as well
mine only runs at 70 but warms up in traffic
