Vtec My Mini ! Obd2B ?
2 replies to this topic
#1 Bigedd95
Bigedd95
  • 51 posts
Posted 05 December 2012 - 11:27 AM
Hello there .
I am restoring my classic mini and have just installed a role cage . I have now decided with the extra weight i will need extra power so im am considering taking the VTEC route .
Going to use an allspeed subframe and want to use a b16a2 engine .
I haave been offerd a b16a2 engine from a 1999 civic , Its come with the gearbox and loom ecu ect.
It also is a OBD2B . Will this make things tricky when wiring it up because of the imobiliser ?
Can anyone give me more detail on this ?
cheers
Eddy
#2 KieranB
KieranB
  • 360 posts
  • Local Club: S.U.N.M.C
Posted 05 December 2012 - 10:54 PM
Hello,
Sounds like a good plan, always nice to see another honda transplant. As for the loom it all depends on what you want to do, buy a kit or build your own. i'm not clued up on the OBD variants however I didnt have a clue about mine (OBD1 1998) and i striped and rebuilt my loom and just recently started the engine with it and trust me if i can do it then anyone can.
Heres a few links:
http://honda-tech.co...d.php?t=2987229
http://www.hondatuni...error_codes.php
the next link is from a current build thread done by MrThumb. If your check out post 110 on that thread then thats were most of this info plus more came from
http://www.theminifo...a/page__st__105
Hope this helps, if you do the research then you'll get the rewards :thumbsup:
Kieran
Edited by KieranB, 08 December 2012 - 10:24 PM.
#3 TypeR_Mini
TypeR_Mini
  • 41 posts
Posted 16 January 2013 - 08:25 PM
Have you considered using an odb1 to obd2 jumper harness to run an obd1 ECU without immobilzer? These jumper harmesses usually go for about 60-80USD and will allow you to run your obd2 setup on a much more user friendly obd1 computer.
I have just picked up a 1999 civic wiring harness for my vtec swap and will be using a jumper as well. Honda-tech.com is a great place for engine swap info. Good luck with yours! :)
