Help!... On Removal Of Nearside Radius Arm?
Posted 05 December 2012 - 09:18 PM
Cheers!
Posted 05 December 2012 - 09:27 PM
but you may have already done this ? - it will be well camouflaged with rust
the handbrake cable can hinder things - also the brake pipe - but I assume you have removed both ?
Edited by sledgehammer, 05 December 2012 - 09:31 PM.
Posted 05 December 2012 - 10:13 PM
Posted 05 December 2012 - 10:31 PM
Posted 05 December 2012 - 10:48 PM
you need to swing the arm as far down as possible to take the tension of the spring, if you have hi-los on the back wind them all the way in as this will help.
Posted 05 December 2012 - 11:02 PM
Is it possible to just remove the pin, bearing and bush without taking the whole unit out? cheers
Posted 06 December 2012 - 01:26 PM
Posted 06 December 2012 - 01:49 PM
then you must take of the brake pipe be carefull though as the lug that keeps it inplace on the radious arm is quite weak and you might end up snapping it off (which i did do on one side luckily i have a tig welder as its quite thin aswell)
then it should just come off if all the other relevant nuts and bolts are undone.
p.s also as tiger has mentioned the pin that hold on the rear qaudrant is a clevis pin and i woudnt really try removing this unless you have to
Posted 07 December 2012 - 04:40 PM
I am gutted to be fair.
Posted 07 December 2012 - 06:38 PM
Tried removing brake line and it is absolutely rusted into place and will not budge, it also looks half rounded off before I even got to it. So I am booking it into a garage for next week which is probably going to cost a fortune!
if you want it doing give me a shout, will look after you on price
Posted 07 December 2012 - 07:48 PM
Posted 16 December 2012 - 10:27 PM
Passed the MOT with flying colours ha ha, another year of happy motoring indeed!
