Drive Shaft
Rick27
, Dec 06 2012 09:51 PM
7 replies to this topic
Posted 06 December 2012 - 09:51 PM
HI can someone tell me if the drive shaft on a manual gear box the same for an automatic. I'm trying to convert my front drum brakes to disc and a friend of mine sold me a complete drive shaft w/hubs and caliper already attached. I hoping to the take the assmbely out and in with the new.
Posted 07 December 2012 - 01:25 AM
Don't see any reason why they wouldn't be the same :s but Ive never worked on a auto so wouldnt know for sure.
Posted 07 December 2012 - 09:47 AM
Just take the shafts out of the outer CV joints and use your old ones. The outer spline is always the same.
Posted 07 December 2012 - 04:26 PM
Hence why it's sensible to just use the original shafts
Posted 07 December 2012 - 07:27 PM
So long as the Hardy-Spicer outer fittings are fitted and will fit the shafts. If not, you'll need earlier shafts, like the Cooper 'S' ones.
Posted 07 December 2012 - 09:32 PM
Thank you all for the awesome info. I have a 1978 Layland. I guess I should lift the car up and see the different. Thanks again guys and have a safe ride!!!!
Posted 07 December 2012 - 10:14 PM
If you get stuck I have a pair of Mk.1 Cooper 'S' drive shafts which will take the Hardy-Spicer couplings and which I could be persuaded to sell. They are complete with new CV joints. I am looking for about £60 for the pair plus carriage. PM me if you find you need them.
Posted 08 December 2012 - 09:33 AM
Not sure what you mean. He should use the shafts that he is currently using with his good gearbox. The outer splines for the CV joints are always the same. That way, the inner joints remain as they were.
