Headlight Flasher - Mot Requirement?
15 replies to this topic
#1 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 07 December 2012 - 04:33 PM
As above really, flasher never worked. I've fitted halogen lights and also replaced the stalk unit.
Dip/Main beam work fine. Just no flash.
Is it an MOT fail? >_<
EDIT: Its a 84 CityE and a link to a new relay would be greatly recieved.
Cheers, Jack
Edited by JackF, 07 December 2012 - 04:34 PM.
#2 iMurray
iMurray
    Mild Cheddar
  • 1,396 posts
Posted 07 December 2012 - 04:36 PM
Nope! Mk1s don't have it
#3 GraemeC
GraemeC
  • 7,439 posts
Posted 07 December 2012 - 04:43 PM
Careful with the advice - Mk1's don't have hazard's either but his '84 would fail without them.
#4 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 07 December 2012 - 04:44 PM
horn work?
#5 iMurray
iMurray
    Mild Cheddar
  • 1,396 posts
Posted 07 December 2012 - 04:47 PM
I stand corrected
#6 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 07 December 2012 - 04:56 PM
I think if they are fitted they must work.
#7 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 07 December 2012 - 05:11 PM
At work i often help sit in the cars working lights etc for the main MOT person, we have never checked flashing the lights, or atleast not whilst im there.
If i remember, i will ask tomorrow at work...
#8 charie t
charie t
  • 3,153 posts
Posted 07 December 2012 - 05:26 PM
the flash doesn't need to work for the mot, as long as dip and main beam work and operate correctly
Edited by charie t, 07 December 2012 - 05:26 PM.
#9 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 07 December 2012 - 05:31 PM
As above, flashing the headlights is not checked. Mine hasn't worked since I've had it and I CBA to fix it.
#10 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 07 December 2012 - 09:59 PM
Thanks for they responses guys. I didn't think it would be a fail, but I wanted to see if anyone knew.
In reply to Jordie, horn works fine.
Could anyone direct me roughly as to where the flasher relay should be situated on the car?
Jack
#11 charie t
charie t
  • 3,153 posts
Posted 07 December 2012 - 10:05 PM
There isn't one, its the switch thats it
#12 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 07 December 2012 - 10:19 PM
How strange. Any ideas at what the problem could be?
#13 charie t
charie t
  • 3,153 posts
Posted 07 December 2012 - 10:27 PM
the switch
#14 samsfern
samsfern
  • 5,243 posts
Posted 07 December 2012 - 11:12 PM
Flash dont need to work for mot, just main beam has to stay on on the switch.
#15 tiger99
tiger99
  • 8,584 posts
Posted 08 December 2012 - 11:29 AM
The headlight flasher is fed by a fuse, which may have failed. The headlights themselves, for safety and legal reasons, have no single fuse, although later models have seperate fuses for main and dip, left and right, which is safe and legal, because a blown fuse does noty lose both lights.
As to which fuse, it varies by model and year, may be an in-line fuse or in the box, but the wire colours are always consistent on a Mini and will be brown (permanent live) on one end of the fuse and purple on the other. The same fuse usually feeds the horn.
If it is not the fuse, it is most likely the switch, as already suggested, but check the connectors on the steering column, and especially the purple wire, which should have 12V on it.
