Coil Wiring
5 replies to this topic
#1 tony13
tony13
  • 267 posts
Posted 07 December 2012 - 05:53 PM
Hi, just wondering what wires go to the coil on a 1275 with a ducieller distributor and where they go to? Cheers
#2 richw911
richw911
  • 2,084 posts
Posted 07 December 2012 - 06:01 PM
Electronic?
The white wire from the module goes to the positive side and the black/white to the negative.
#3 tony13
tony13
  • 267 posts
Posted 07 December 2012 - 06:09 PM
I've got A thickRed wire and a thin ehite wire coming off the loom and I've got the condenser wire going on to the right hand side of the distributor?
#4 ado15
ado15
  • 614 posts
Posted 08 December 2012 - 09:39 AM
Hmm. There was never a red wire for the coil. This isn't an Innocenti is it? The Italians were a law unto themselves!
Non ballast systems had the white for +ve and black/white for -ve as Rich pointed out.
Ballast systems (approx. 1984 to 1992, except electronic) had a white/yellow and white/pink to go to the +ve side and the same black/white for the -ve side.
Edited by ado15, 08 December 2012 - 09:40 AM.
#5 tractor
tractor
  • 662 posts
Posted 08 December 2012 - 09:49 AM
Maybe a pic would help?
Trac
#6 tiger99
tiger99
  • 8,584 posts
Posted 08 December 2012 - 03:56 PM
ado15 is correct, but there may be another white-black, same terminal, if you have a tacho.
Does the red wire look as if it does not belong, or been added as an unofficial modification? Red is only used for side and tail lights, and the wiring colours are consistent across all UK made Minis. (Don't know about Innocentis, as has been said.)
