Intermittent Side Lights
4 replies to this topic
#1 Ocado Man
Ocado Man
  • 186 posts
Posted 08 December 2012 - 07:08 PM
Lulu has developed an intermittent lighting problem. Every so often the side lights (including rear lights) & instrument panel lights fail to light. The headlights & rear fog are fine. I think the obvious cause is a faulty earth but can anyone shed some light (excuse the awful pun) on where to look. I have fiddled with fuses & fuse holders. I have disconnected & reconnected wires at the slam panel all to no avail. I also thought that it may be the light switch. Any thoughts?
Daren't go out in the dark now.
Lulu is 1994 Sprite 1275
Edited by Ocado Man, 08 December 2012 - 07:10 PM.
#2 Ocado Man
Ocado Man
  • 186 posts
Posted 10 December 2012 - 02:04 PM
No worries, I think I've tracked down the problem. It wasn't the switch (luckily I had a spare), wasn't the wires at the slam panel, it was the fuse box. Fuses were A Ok, it looks like a dodgy box. When I wiggled (dead technical) the connections the lights did their thing. I'm off to MiniSpares to replace the box.
#3 Ethel
  • 26,580 posts
Posted 10 December 2012 - 02:23 PM
Water can get behind them 'n cause shorts, it's as likely to be the wiring as the fuses. You could swap the lot with one of the other 3 - fuse & all its wires.
#4 Ocado Man
Ocado Man
  • 186 posts
Posted 10 December 2012 - 05:25 PM
Ethel there is something peculiar with the fuse box though. I had the side lights on, removed the wire from the output side & hey presto they went out (as expected), replaced. I then took the feed wire off & again they went off (as expected). But........... when I removed the fuse, they stayed lit. Not sure what is going on there. I would have thought that the power would have been going through the fuse.
#5 Dmartin3093
Dmartin3093
    Just On Tickover
  • 7 posts
  • Local Club: LSMOC
Posted 16 March 2013 - 04:22 PM
I have the same problem ive run a live from the battery to the rear lights and have to keep putting in a fuse when eva i want my side lights, i will try this tmorrow :) hehe thx for having the same problem as me :)
