More Camber
3 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 09 December 2012 - 09:41 AM
if i put bit more camber on does it give more caster or less
and asume it will give more toe out
also does shortening tie rods give more camber or other way round
#2 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 09 December 2012 - 09:43 AM
if you wind on a big more nagative camber then you will get a bit more toe out, but thats easily dialed out.
if you change the length of the bottom arm then you will need to lengthen the tie rod aswell. tie rods dont affect camber greatly.
#3 racingbob
racingbob
  • 3,061 posts
Posted 09 December 2012 - 09:52 AM
does shortening tie rods give more or less caster
#4 absx2
absx2
  • 918 posts
Posted 09 December 2012 - 10:08 AM
More castor :) Don`t forget to reset your tracking.
Edited by absx2, 09 December 2012 - 10:09 AM.
