Replacing Rear Wheel Stud.
8 replies to this topic
#1 ricekikr
ricekikr
  • 173 posts
Posted 10 December 2012 - 05:48 AM
Does the hub need to be off to get the studs on? The studs are hitting the backing plate.
Am I doing this the wrong way, is there an easy way to this? Posted Image
I'd rather drill a hole thru the backing plate if the hub needs to be removed to install studs. No way am I gona pull the hub off every time a stud breaks.
#2 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 10 December 2012 - 06:54 AM
Hub has to come off!
It's not a huge task,, replace all the studs and you won't really have to worry anymore)
#3 ricekikr
ricekikr
  • 173 posts
Posted 10 December 2012 - 07:44 AM
I thought I was doing it wrong when I couldn't find a hole in the backing plate lol.
Hasn't anyone drilled a hole thru the back plate? 1/2" hole at most.
#4 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 10 December 2012 - 08:26 AM
How often do you break studs?!
#5 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 10 December 2012 - 08:38 AM
I wouldn't drill any holes in the backplate. Just asking for trouble like water in the brakes etc drillingt through something ...
Just pull the hub off, takers about 10mins:P
#6 ricekikr
ricekikr
  • 173 posts
Posted 10 December 2012 - 11:41 AM
What's the torque (lb/ft) for the hub nut? Might try the proper method first.
Or gona try fitting it thru one of the holes (handbrake / slave etc etc)
#7 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 10 December 2012 - 11:52 AM
it doesnt even need 10mins, you just slacken the hub nut until you can get the stud out and just put in the new one and re-tighten it
#8 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 10 December 2012 - 11:59 AM
Remember to check what side you are doing in the Haynes, one side is a left hand thread so you dont want to bugger it up by tightening up if you think you are un doing it..! Like i done once....
#9 ricekikr
ricekikr
  • 173 posts
Posted 10 December 2012 - 01:43 PM
Thanks for the info. Gona try it out tom.
Thanks for the tip. Right side = right hand thread = counterclock to loosen.
It is 1.5" right?
