Front Brake Disc Heat Shields
8 replies to this topic
#1 Mini118118
Mini118118
  • 86 posts
Posted 10 December 2012 - 09:49 PM
Hi guys one of my front brake disc heat shields is rattling due to one of its securing brackets broken, my question is are they really neasasary, can I get away with just removing them both. Would it be an m.o.t. Failure... Most minis I've seen have removed them ...thanks
#2 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 10 December 2012 - 09:52 PM
Not an MOT requirement no.
#3 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 10 December 2012 - 10:03 PM
Binning them is the permenant solution
#4 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 10 December 2012 - 10:04 PM
i usually take them off to be honest, as usually they are pretty cruddy, or as you have found on yours, they end up with broken brackets and would only rattle if left.
#5 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 10 December 2012 - 10:11 PM
More hassle than they are actually worth, get rid, no issues with MOT, just with your sanity
#6 Mini118118
Mini118118
  • 86 posts
Posted 10 December 2012 - 11:06 PM
Nice! thanks consider them gone....cheers
Edited by Mini118118, 10 December 2012 - 11:07 PM.
#7 mab01uk
mab01uk
  • 12,434 posts
Posted 11 December 2012 - 12:01 AM
Just be aware on long motorway drives in wet conditions if you have not used the brakes much, on the first application they may not 'bite' quite as expected due to water spray on the discs. Has happened to me a couple of times.
#8 Cooperman
  • 23,294 posts
Posted 11 December 2012 - 12:12 AM
That can happen with virtually any car. Most modern cars don't have brake inner shields.
I once got a small stone behind a shield on my wife's classic old Merc 450SL. I thought a wheel bearing was breaking up!
#9 1984mini25
1984mini25
  • 8,784 posts
Posted 11 December 2012 - 12:28 AM
3 options, weld the bracket back on (don't need to remove from the car to do so), replace it, but that would mea pulling the disk and flsnge off as well. Or the last option is to remove both and just not bother with them.
Although it could fail an mot if left with it rattling around.
