Body Filler?
7 replies to this topic
#1 aml1989
aml1989
  • 25 posts
Posted 11 December 2012 - 04:46 PM
Hi guys!
I'm Andy from Edinburgh, and it's my first post on TMF! Bought myself a 2000 Rover mini cooper (and love it), next on my to-do list is some bodywork. Got some colour blending practice on my old corsa before I sold it, but it didn't need any filling.
Some rust at back of the a-panels (door hinges are concealed type), just wondering if that needs welded or if i can get away with filler. Slightly worse on driver's side than passenger, no evidence of rust near the hinges.
Attached File  11122012493.jpg   55.62K   14 downloads
Rust under rear window (driver's side). Felt some damp on the rear seat the other day, So I'd like to do that one first (and check window seal). Again, is this okay with just filler to smooth it over?
Attached File  11122012492.jpg   57.39K   10 downloads
Finger-size hole in bonnet, with bubbling around it - will filler take the heat?
Attached File  11122012494.jpg   39.58K   13 downloads
Minimal work will be done until it's warmer, or I can get the car under cover - just after advice for now.
#2 mattbeddow
mattbeddow
  • 337 posts
Posted 11 December 2012 - 04:53 PM
You can filler it but i strongly suggest you do the job properly.
If you filler it, the rot will continue and youll have an even bigger problem in a few months time.
Start by sanding it all back untill there is no more rust, then make a decision. if you can make a bit of metal to weld in place of what youve removed then stay clear of the filler.
Also, the bonnet and filler are a bad idea, after a few opens and closes, it will start to crack around the edges and youll have to start again. This is defiantly a new metal job
Edited by mattbeddow, 11 December 2012 - 04:55 PM.
#3 Sam
Sam
    Wish i was in T.O.W.I.E
  • 2,323 posts
Posted 11 December 2012 - 05:00 PM
Those A panels will need replacing, and the bit under the window needs cutting out and a new bit welding in.
You may be able to cut out the rust on the bonnet and weld a new bit in, but the easiest way is to get a new bonnet.
#4 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 11 December 2012 - 05:10 PM
Will proably be best to find a good condition second hand bonnet, and paint it. Under the windo you could weld in a repair section. Are the windows opening ones or fixed? If they're openable ones, post another pic up with the window open, the repair may need to be bigger that it first looks (mine is rotten all the way under the windows), And definatly best to replace the A panels.
Hope this helps :)
#5 Algordo1100
Algordo1100
  • 774 posts
Posted 11 December 2012 - 05:39 PM
Welcome!
Dont fill rust fella. get some new metal in there ;-)
Al
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 11 December 2012 - 05:42 PM
Welcome!
Al
I second this
#7 aml1989
aml1989
  • 25 posts
Posted 11 December 2012 - 06:56 PM
Wow - that's a lot of quick replies!
Will get a pic of the window open when it's light, I did buy some filler but kept the receipt.
Guess I'll need to learn to weld :)
Plenty of paint bubbles to practice colour matching with in the mean time.
Thanks guys!
- Andy.
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 11 December 2012 - 07:16 PM
The A post flange that the A panel wraps around will be rusty as well. If you are lucky then a repair piece will sort out the top of the rear quarter panel but the rust will have taken into the waist rail as well. It tends to start in between the quarter panel flange and waist rail flange.
With the bonnet if its gone up that far then alomg the front edge behind the trim panel will be rusty as well. Get a second hand one.
