Is A Boost Gauge Necessary?
Posted 11 December 2012 - 10:42 PM
Do you need a boost gauge? What are the pros/cons (if any) of having one? What should the gauge read?
Many thanks
Andy
Posted 12 December 2012 - 10:25 AM
Posted 12 December 2012 - 12:13 PM
Posted 12 December 2012 - 12:25 PM
If you carb is before the SC its suck through, if its after the SC its blow through.
Posted 12 December 2012 - 12:27 PM
Once it's set up and working properly you could remove the guage
Posted 12 December 2012 - 12:36 PM
Posted 12 December 2012 - 01:25 PM
Posted 12 December 2012 - 01:32 PM
Posted 12 December 2012 - 01:53 PM
http://www.secondcha.../public/186.cfm
Posted 12 December 2012 - 02:46 PM
Posted 12 December 2012 - 05:04 PM
Posted 16 December 2012 - 11:48 AM
I have said it before and will say it again. If you have to ask these questions don't do it. If you don't understand any of it your in for a disaster. There is books available that will explain all the underpinning knowledge of forced induction. In my opinion its a waste of money if it goes bang.
To be fair, he did say he wanted the van regardless of the engine. He hasn't asked a stupid question really.
For an SC, a boost gauge is really not much use. In a turbo car it has more benefits as you can adjust the boot levels and you need to know what it is.
Posted 19 December 2012 - 09:20 PM
Posted 19 December 2012 - 10:09 PM
if you have any running problems later on, the gauge may be able to give you some valuable information. if you start to suspect its not running right, or its not as quick, or maybe you start thinking you can hear an air leak, the gauge could help you decide if this is the case.
i remember many years ago, my first mini had a vacumm gauge (fitted for ecconomy purposes in my student days) not only did it allow me to get better fuel consumption when the funds got tight at the end of the month, but it also used to read differently when the head gasket went between cylinders 2&3, which seemed to happen on a fairly regular basis, until i eventually got it skimmed and it never happened again.
in my opinion, fit the gauge, just dont crash because your watching that not the road lol!
