Su Carb Problem
Posted 12 December 2012 - 03:47 PM
Is there anything I can do to fix this, if not what carb should I go for? Another SU or should I upgrade?
Posted 12 December 2012 - 04:02 PM
Does it form a loop?
Is there any springiness when you move jet by hand?
Is the choke knob harder to pull out?
Seized linkage somewhere, missing/broken return spring, bent jet - all possibilities and much cheaper than a new carb.
Posted 12 December 2012 - 05:33 PM
Posted 12 December 2012 - 06:10 PM
I'm changing the head and almost everything but the short block that's why I was thinking of a new carb, il have a double check tomorrow see if I can solve it as I didn't really have a proper look today I was busy undersealing, it may just be getting caught on someone when pulled out but the spring looks like it doesn't even try to return.
Edited by alsy, 12 December 2012 - 06:26 PM.
Posted 13 December 2012 - 12:12 AM
Posted 13 December 2012 - 07:33 AM
The choke is harder to pull out for sure, but pulls out and works as it should, but the when pushed back in the cable just kinda bends up and the spring bit doesn't return so the cars acting as if the chokes still out.
You can buy service kits fro the SU carbs - it would be well worth giving it a full clean and service while it is off if it hasn't had any TLC in a while...
Posted 13 December 2012 - 04:33 PM
Posted 13 December 2012 - 05:09 PM
Posted 13 December 2012 - 05:22 PM
Posted 13 December 2012 - 05:28 PM
Sounds like it might be a bent jet. The service kit should include a replacement.
You are certainly correct. If the engine rocked badly enough the jet may have hit the bulkhead and become bent. I had not even thought about that possibility.
There are major and minor service kits. The basic inexpensive kit will not include a jet. I would examine the removed carb to see if the jet is bent before buying the more expensive kit.
Posted 13 December 2012 - 06:19 PM
gasket kit is just gaskets, service kit has jets and float valves etc and a re build kit has spindles, bushes and butterflies etc.
the hs su is a bloody awful carb, you've only got to look at them wrong and the bloody spindle wears away!!
if you want it sorting/rebuilding give me a shout.
Posted 13 December 2012 - 07:47 PM
Posted 13 December 2012 - 09:59 PM
Posted 13 December 2012 - 11:24 PM
Posted 14 December 2012 - 09:32 AM
