Heater Flap
5 replies to this topic
#1 pierres
pierres
  • 586 posts
  • Local Club: No
Posted 13 December 2012 - 12:14 PM
Need to put some sort of foam or other material on the flap of my heater so it makes a good seal to get more heat to windscreen. My question is can this be done with the heater in the car or not or can the flap be taken out with heater in car
#2 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 13 December 2012 - 12:28 PM
No, in order to get to the flap you need to remove the heater box and take it apart (a few screws around the edges). It's a fiddly but straightforward job. This is unless you have magic fingers which can get through the holes in the heater and stick the foam on, which I doubt, and wouldn't turn out great anyway ;D
Have you checked the air pipes aren't cracked along the way up behind the dash, or loose at the top by the windscreen vents?
#3 pierres
pierres
  • 586 posts
  • Local Club: No
Posted 13 December 2012 - 01:49 PM
All pipes are ok and tapped at each end
#4 tiger99
tiger99
  • 8,584 posts
Posted 13 December 2012 - 06:44 PM
While the heater is out, I suggest that you take the opportunity to use a hose to flush it out. It will only take an extra couple of minutes and you will be amazed at how much muck and silt accumulates in there, which does not exactly help the heat output.
#5 lewBlew
lewBlew
  • 1,238 posts
Posted 13 December 2012 - 07:19 PM
Agree, and if you do take the coolant pipes off the matrix make sure you bleed it afterwards otherwise it'll run lukewarm because of air inside it. It's the lowest point of the coolant system (I think) so get a funnel and fill the upper intake pipe with coolant/water before you reattach the hose.
#6 shabir
shabir
  • 346 posts
Posted 14 December 2012 - 10:53 PM
this is something i need to do aswell, i get no air at all on the windscreen which is annoying!!!
