What you get
- Megajolt/E (MAP) with Hard Cut Limiter (NOTE not the standard soft cut)
- Full loom (already wired so plug and play)
- Brand NEW VR sensor (had as spare from kit i bought previously)
- EDIS Ignition Module
- Coil Pack & Mountable Bracket
- Bosch HT Leads
- MJ RJ11 <-> DB9 Serial Tuning Cable
- Serial <-> USB Adaptor
To give you an indication of the layout of this on my car i had the MJ under the dash rail inside the car, the EDIS mounted to drivers wing side on the bulkhead and the coil mounted on the inner wing. Piccy below shows this roughly. You can see the EDIS and the Coil was just behind the oil catch tank you can see on the left.
ace cafe aug12 by lilpinkiy, on Flickr
Looking for £260 ono posted.
I'll post up more piccys later of the items out of the car.
Chris
Edited by t@z, 18 December 2012 - 12:25 PM.
