Right Hand Tank Fitting Instructions / Boot Board Bracket Fitting Instuctions
8 replies to this topic
#1 kinger59
kinger59
    Just On Tickover
  • Just Joined
  • 5 posts
Posted 23 December 2012 - 09:43 PM
Finally got my right hand tank fitting kit but no instructions or diagrams or measurements as to where to weld parts in and same for boot board brackets. Could anyone please help with advice, diagrams etc as hoping to do job
over christmas holiday.Cheers.
#2 mk1leg
mk1leg
  • 9,343 posts
Posted 24 December 2012 - 10:38 PM
this may help you...... :proud:
brackets fitted to boot floor and seat back...
tank installed.....
link pipe fitted.....
facet fuel pump fitted on rear sun with rubber cotton reels...
Edited by mk1leg, 24 December 2012 - 10:39 PM.
#3 RobbieP
RobbieP
  • 73 posts
Posted 09 September 2013 - 05:24 PM
So this is a single pump set up that relies on the fuel to fill via the line from the other tank? ONly pumping from one?
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 September 2013 - 08:53 PM
  No the main fuel line between the tanks is one huge Tee-piece with the pump in the middle.  The pump draws form both simultaneously, there is no separation.
#5 nz_seamless
nz_seamless
  • 68 posts
Posted 10 September 2013 - 03:14 AM
I'm curious why BMC did the twin tanks, was it a weight balance thing? Range for the sportier cars?
Is carrying more fuel a drag?
#6 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 10 September 2013 - 03:17 AM
5.5 gallon fuel tanks don't get you far!
#7 nz_seamless
nz_seamless
  • 68 posts
Posted 10 September 2013 - 03:50 AM
Granted it's not a monster sized tank but then minis hardly plow through petrol either :)
#8 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 10 September 2013 - 04:08 AM
Australian homologation cars of the 60's and 70's had 100+L tanks..
The E49 had a 35 gallon tank
http://www.shannons....EJSK561A6Q39TH/
The FOrd XY GTHO Phase III had a 36 imp gallon tank (136L)
Edited by timmy850, 10 September 2013 - 04:08 AM.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 September 2013 - 11:55 AM
  To get more fuel in, that was all.  The rally team needed more fuel so it may have been for homologation.  The RH tank was an option originally though before it became standard on the Cooper S.  In effect it throws the balance out a little because the battery weights more or less the same as a half full 5 1/2 gallon tank.
