Fitting A Maniflow Exhaust ?
12 replies to this topic
#1 Ddotscott
Ddotscott
    Starting My Mini Up
  • 2 posts
Posted 25 December 2012 - 10:51 PM
Hello
I am Looking to purchase a Maniflow 1.75" side exit exhaust and LCB and was wondering what mounting parts I would need or if the exhaust comes with one. I know there are kits for the RC40 exhaust that is the same diameter but I don't know whether it will fit or not. Please forgive me if this a stupid question but I'm new to minis. :)
Duncan
#2 IainNeon91
IainNeon91
  • 1,287 posts
Posted 25 December 2012 - 11:16 PM
Hi there Duncan :-) A quick search on the forum will find you the answer to this question, im sure. But as it's Christmas i will give you my best answer :D
You will need to buy one of these:
http://www.minispare...01.aspx|Back to
There is a good fitting guide i found /w pictures:
http://myminiproject...ucy/mini41.html
Once fitted it should look a little something like mine :D
Hope this helped and good luck!
Iain
#3 Ddotscott
Ddotscott
    Starting My Mini Up
  • 2 posts
Posted 25 December 2012 - 11:23 PM
Thank You! it helps a lot! :)
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 26 December 2012 - 10:38 PM
On Maniflows site they have a HD Fitting kit available for the side exit 1.75inch where I got mine from.
#5 danm
danm
  • 502 posts
  • Local Club: Stringfellows
Posted 22 August 2014 - 03:54 PM
bumped for usefulness! :) Thanks!
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 22 August 2014 - 05:42 PM
I used a stainless jubilee clip as the rear clamp look terrible turned down and there is not room to turn mine upwards.
#7 welldc
welldc
  • 92 posts
  • Local Club: Robin Hood Mini Club
Posted 12 September 2014 - 11:06 AM
Is there just a mounting at the back?
I've had a new Maniflow twin box system fitted and after a short run, the pipe pulled out of the back box. Clamps were tight, but not mega tight.
At idle, the whole exhaust from front to back sets up a vibration. The rear mount is two stiff bobbins on the subframe and a normal hanger. There is almost no movement if you swing on the end of the tailpipe.
Just wondering if there should be a mount in the middle somewhere to damp out the vibration and if the bobbins are too stiff?
#8 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 12 September 2014 - 11:17 AM
How are the engine mounts?
#9 welldc
welldc
  • 92 posts
Posted 12 September 2014 - 12:06 PM
Almost no movement if I swing on the engine, but don't know about the mounts. Do they go soft or tear away?
#10 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 12 September 2014 - 01:00 PM
I swapped out the solid mount that is located just before the back box (attached to the cross beam under the rear seats) to a rubber belt type one and its cut a lot of vibration noise out of the cabin - I think you get the solid metal mount with the kit?  My rearmost bobbins are rubber and metal and damp vibration at that end. The rubber belt and hook mounts in that there Halfrauds do the job, not sure how long they last but can be cut down and drilled to suit the job.
#11 pogie
pogie
  • 498 posts
  • Local Club: Essex MC
Posted 12 September 2014 - 04:02 PM
The middle mount shouldn't be solid, it should be one of these rubber jobbies - http://www.minispare...px|Back to shop
#12 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 12 September 2014 - 04:26 PM
I used the RC40 one, but if you order from maniflow itself the injection stage one kit I ordered came with fitting clips etc etc, I now after taking my exhaust off now have a mixture of the two on and have no air leaks or anything.
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 September 2014 - 05:19 PM
Yep I just used the full kit from maniflow with no issues except the clip I used on the tailpipe as it looks neater
