Removing Paint And Primer
15 replies to this topic
#1 miniloverswife
miniloverswife
  • 24 posts
Posted 26 December 2012 - 10:55 PM
Hi me and my husband have been trying to remove some primer which has been put over the top of the original colour paint and primer on his mini which he got for xmas, although old owner said it was ready to paint its def not and the roof has even been spray painted ! We have been using sand paper and then had a go with a grinder tonight just wondered if anyone had any tips to make it quicker /easier or to get the best finish? Or if anyone can rrecommend attachments fornthr grinder or drill to do a bigger area quicker ? Thanks a lot Suzanne
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 26 December 2012 - 10:56 PM
a wire cup brush on a angle grinder workds well
#3 miniloverswife
miniloverswife
  • 24 posts
Posted 26 December 2012 - 11:14 PM
Thanks a lot weve ordered a set with different sizes for a drill but will look into getting one for then grinder thanks for replying also do have any recommendations for primer so we can cover the car once down to bare metal
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,045 posts
  • Name: Neil
Posted 26 December 2012 - 11:15 PM
+1 although it does take time. DO WEAR GOGGLES and gloves. Use the twisted wire cup ones like this
http://www.ebay.co.uk/itm/Silverline-65mm-Rotary-Wire-Brush-Twist-Knot-Bowl-Cup-wheel-M14-angle-grinder-/400347994645?pt=UK_Home_Garden_PowerTools_SM&hash=item5d36999a15
#5 sonikk4
sonikk4
  • 16,045 posts
  • Name: Neil
Posted 26 December 2012 - 11:16 PM
Use Upol etch primer. You can get this from Halfords. Do remember most primers are porous so keep water off.
#6 miniloverswife
miniloverswife
  • 24 posts
Posted 26 December 2012 - 11:35 PM
will do the cars being kept into the garage and were going to do one area at anytime starting with the roof wenwore masks but did think we should prob have goggles on! Will have to get some and I'll have a nosey at your link thanks :)
#7 sonikk4
sonikk4
  • 16,045 posts
  • Name: Neil
Posted 26 December 2012 - 11:40 PM
I had eleven layers of paint on Project Erms roof and it took me a solid day to remove it all. And i did it with a twisted wire cup and a DA sander. All very messy.
#8 miniloverswife
miniloverswife
  • 24 posts
Posted 26 December 2012 - 11:53 PM
I think this has about 6 very dusty lol we get through top layers quite easily but original colour an pale yellow and grey primer layers I'm guessing are better quality and takes a bit more elbow grease! :)
#9 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 26 December 2012 - 11:56 PM
i used a mix of paint stripper, DA sander with 80 grit and the wire wheel on the grinder (for in the gutters! but be carefull of it snatching). Make sure you clean the gutters right back to clean metal as people fill these areas often. :)
#10 miniloverswife
miniloverswife
  • 24 posts
The old owner had even sprayed over stickers of websites on the roof and under rear windows on both sides the car wasn't even that bad til he sprayed over it!
#11 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 27 December 2012 - 12:06 AM
i just use solvent based stripper. can do a full car in a couple of hours.
#12 daviedevil
daviedevil
  • 200 posts
  • Local Club: BD developments
Posted 27 December 2012 - 09:01 AM
There is a specialist firm close to me in Preston called ribble technology that remove paint by putting it in an oven over night as a bare shell.
They have just done a mk2 and a pickup. They'll put a fancy primer on afterwards too of needed.
I'm not an associate of the firm but they've just done a job for my gaffer and was very impressed.
#13 miniloverswife
miniloverswife
  • 24 posts
Posted 27 December 2012 - 11:40 AM
Hi thanks for replying bit far for us anprob expensive were skint at the min lol would of been good though! :)
#14 miniloverswife
miniloverswife
  • 24 posts
Posted 27 December 2012 - 11:41 AM
#15 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 27 December 2012 - 11:42 AM
Best get one for a grinder, drill ones are painfully slow and knacker the drill as they aren't meant for side loads
