Manifold Washers
14 replies to this topic
#1 jpw1275
jpw1275
  • 2,803 posts
Posted 27 December 2012 - 02:16 PM
Hi all.... Hope everyone had a great christmas.... Just a quick one, I've searched but too no avail.... I'm sure I've seen somewhere if not on hear a set of manifold washers which are stepted to accommodate the difference between inlet manifold and exhaust manifold so you get an even pressure...any pointers are very welcome
Cheers james
Edited by jpw1275, 27 December 2012 - 02:17 PM.
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 27 December 2012 - 02:26 PM
Had a quick look couldn't find any...They are normally only needed when using mixed parts.. such as mg metro inlet with a LCB manifold.
We filed the inlet manifold to the same thickness as the exhaust manifold to get round it.
Although making your own washers would work
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 27 December 2012 - 03:19 PM
the cheapend end products have thinner thickness flanges hence the problem when mis and match, generally the better end products all have one thickness of flange 8mm but in your case its a handmade washer to do the job and the difference is about 2 mm so 8mm on manifold flange and 6mm on the inlets but measure before making anything
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 27 December 2012 - 05:43 PM
Not so sure its anything do with cheapness.
The inlet we used was MG Metro and the exhaust was an RC40 system from minispares. Still had a mismatch
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 27 December 2012 - 07:41 PM
just grind the higher lobes down to lower........its not difficult.......then just use std washers..... :proud:
Edited by mk1leg, 27 December 2012 - 07:42 PM.
#6 A-Cell
A-Cell
  • 1,610 posts
Posted 27 December 2012 - 08:19 PM
Just make your own stepped washers from standard ones. File one side to reduce it by the appropriate (measured) amount.
#7 tiger99
tiger99
  • 8,584 posts
Posted 28 December 2012 - 10:20 AM
You could cut a washer in half and weld it around the outer edge to a full washer, if that gives you the correct difference in thickness.
Or, you could visit a scrappy to see if some other car has something suitable. On a Mini the studs are 5/16", but washers for 8mm studs are equally acceptable.
#8 blacktulip
blacktulip
  • 6,224 posts
Posted 28 December 2012 - 11:19 AM
i thought minispares did these?
but i would just file the inlet to match the exhaust manifold. i did this once and it saves faffing about finding the washers and also if you were to lose one whilst working on the engine it wont stop you from carrying on.
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 December 2012 - 01:12 PM
The cheaper LCBs had thinner flanges and yes so does the Metro inlet which was originally matched with a cast iron manifold of the same thickness, and in general the cheap LCBs are thinner read Keith Calvers report on exhausts its all there.
#10 tiger99
tiger99
  • 8,584 posts
Posted 28 December 2012 - 01:40 PM
Sometimes you can't safely file a cast manifold, and if it breaks it is a very major annoyance. A steel manifold usually can be filed, but if you go too thin it may warp, so be careful if you go for that option.
#11 A-Cell
A-Cell
  • 1,610 posts
Posted 28 December 2012 - 03:12 PM
Just file flats on 4off 12A1211 thick manifold washers. Do another for a spare at the same time if you want. Take you about 30 mins. No cracking or manifold distortion to worry about.
#12 A-Cell
A-Cell
  • 1,610 posts
Posted 28 December 2012 - 04:06 PM
Agree, this will provide more support, ideally braze them, then file or machine.
#13 jpw1275
jpw1275
  • 2,803 posts
Posted 28 December 2012 - 04:13 PM
cool cheers guys thanks for the help....much appreciated..:)
james
#14 A-Cell
A-Cell
  • 1,610 posts
Posted 28 December 2012 - 04:17 PM
Old topic as well http://www.theminifo...nifold-washers/
Hope it goes well for you. Nice to do a bit of fitting rather than just assembling ;-). Have fun
#15 jpw1275
jpw1275
  • 2,803 posts
Posted 28 December 2012 - 04:26 PM
yea im in no real rush as ive got a rear end to assemble after all the welding of hinge panel, boot floor and arches blah blah .... i didnt relise after all the cutting i only had half a car left hehe..;).....once ive finished the rear end end il be turning the car around and the engine is coming out, i just like to have things in place beforehand instead of researching at the point i need it
cheers james
