1976 Leyland 1L Mini Makes Funny Grinding Noise Near The Fan
4 replies to this topic
#1 mckenziecz
mckenziecz
  • 19 posts
Posted 28 December 2012 - 03:04 PM
As above, only does it at higher revs. See videos.
Any help much appreciated. Thanks george
http://i736.photobuc...0369476D190.mp4
http://i736.photobuc...0368AED06CF.mp4
#2 tiger99
tiger99
  • 8,584 posts
Posted 28 December 2012 - 03:57 PM
Well, your fan belt is too slack, but that does not explain the noise, which could be water pump bearings, or even alternator bearings. You need a simple stethoscope, basically a length of wood or a thick screwdriver. Taking great care to avoid entangling it in the belt, put one end on the suspected components and the other end on your ear. You will be amazed at how many noises you will hear, and the one which concerns you will be loudest on the item which is generating it.
But check for simple things like loose fan bolts or a loose cowling too.
#3 mckenziecz
mckenziecz
  • 19 posts
Posted 28 December 2012 - 06:13 PM
Thank you, sounds like a plan
#4 mckenziecz
mckenziecz
  • 19 posts
Posted 28 December 2012 - 07:43 PM
Battery seems to be getting flat and it looks fairly new so that woul suggest I am looking for alternator bearing
#5 tiger99
tiger99
  • 8,584 posts
Posted 29 December 2012 - 04:03 PM
Maybe, but the battery will go flat with a slack fan belt.
