A+ Gearbox Noise
Posted 29 December 2012 - 05:08 PM
Could be my problem
Posted 29 December 2012 - 05:09 PM
how do I edit a postBefore I took the engine out the box was noisy in 1,2, 3 gear but fine in fourth. Today, while taking engine to bits and once I got the flywheel housing off I notice the bearing cage was loose from the bearing
Could be my problem
I meant to say big ball bearing on re input shaft
Posted 29 December 2012 - 05:16 PM
i can't help with the gearbox troubles but the edit button is next to the quote button in the right hand cornerhow do I edit a post
Could be my problem
Posted 29 December 2012 - 05:46 PM
Could be my problem
If the single roller has broken down then yes.
