Med X Pin Diff Any Good
10 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 29 December 2012 - 09:12 PM
As title says really . Started to do my gearbox today and now found the diff is worn well parts in diff are worn . I can just rebuild it but iv seen alot of people just go for x pin diffs so going to buy a new diff
Hat are med ones like any problems with them ?
And can i use the standard diff ratio with an xpin
Engine is a 1380
#2 minilee94
minilee94
  • 3,523 posts
Posted 29 December 2012 - 09:27 PM
Oh right okay thank you mate is there any better diffs out there thats the same price or would you say there all the same
#3 The Principal
The Principal
  • 763 posts
Posted 30 December 2012 - 07:24 AM
If you consider using the old fibre washers check the output shaft end float back into the planet gears, i've had difffs wheres the fibre washers have worn to a fag paper thickness and in one case completely worn through. Mini Spares do two thicknesses of fibre washer the BTA 101 and BTA102
http://www.minispare...px|Back to shop
#4 minilee94
minilee94
  • 3,523 posts
Posted 30 December 2012 - 07:55 AM
I might aswell replace them right? And why are there 2 sizes what should i get
#5 The Principal
The Principal
  • 763 posts
Posted 30 December 2012 - 08:04 AM
they are usually replaced which size depends on the wear/mileage of the car. the thicker washer can lock the diff
check out this link for more info - http://www.theminifo...=163597&hl=diff
Edited by The Principal, 30 December 2012 - 08:05 AM.
#6 minilee94
minilee94
  • 3,523 posts
Posted 30 December 2012 - 09:06 AM
Were abouts are these shims exactly and the engine was apparently on around 40k
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 December 2012 - 09:34 AM
The above link is more to do with shimming the diff when placed in the gear case, not the actual build of the differential...
Here's a basic guide to building the x-pin.... http://www.guess-wor...m/Tech/Xpin.htm
and also available from me, and take note that I offer to build your differential for free if you send me your complete old unit.
http://www.guess-wor...play.htm?id=111
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 December 2012 - 10:36 AM
You may wish to read this.... all x-pins are not made equal...
http://www.theminiforum.co.uk/forums/topic/81183-the-diffrence-between-diffs/
#9 minilee94
minilee94
  • 3,523 posts
Posted 30 December 2012 - 10:40 AM
Thanks for the offer guess works but i was going to try and do it myself so i can learn i wilm bare it in mond that i can send it to you tho :) so really i just need to order a new diff and just assemble it
Should i also replace the big bearings on the diff to
#10 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 30 December 2012 - 10:58 AM
I too have used the minispares 4 pin with no problems. I have alctually yet to see a worn one!!I I built one only yesterday, and it went together very well.
AC
#11 minilee94
minilee94
  • 3,523 posts
Posted 30 December 2012 - 11:02 AM
Okay so the med one is the minispares one then :) if so il be having one alot or people have given good ratings on them
