Hammerite Help.......
Posted 30 December 2012 - 12:12 PM
I really wanted to get this job finished today but the only other red paint I have available is Hammertite. Anyone used it for engine painting? I don't think cylinder heads should get too hot but the last thing I need is to put the engine back and then to have to strip it all out again if the paint blisters...........
Advice and successful experiences appreciated.
Bob
Posted 30 December 2012 - 12:16 PM
Posted 30 December 2012 - 12:25 PM
Hammerite Smooth is good. Used satin black ok. Halfords is open!
Hammerite smooth it will be then. Cheers.
Bob
Posted 30 December 2012 - 12:32 PM
Edited by SA MINI, 30 December 2012 - 12:33 PM.
Posted 30 December 2012 - 01:38 PM
Also when it goes like jelly you will find its just the top layer has dried out & turned into a rubber film you can pierce it & the rest of the paint underneith is usually fine
No, unfortunately the whole content was like jelly and wouldn't even stick to the Mk. 1 stirring stick (a screwdriver) so I figured it was past its best.
Bob
Posted 30 December 2012 - 01:44 PM
Posted 30 December 2012 - 04:36 PM
We've just painted an essex v6 with yellow hammerite too.
Posted 30 December 2012 - 08:10 PM
Hammerite red was fine on our crossflow engine apart from around the exhaust ports, where it went black. But so has halfords engine enamel. Think the engine runs hot anyway as it's high compression. The hammerite elsewhere did start to bubble a little bit, so we went over it with engine enamel, but as said, it's a hot engine.
Thanks. I went ahead and used the Hammerite anyway. Reasoned that it really shouldn't get much over 105 - 110 degrees with the cooling water circulating and that's probably not much hotter than metal left in the sun gets.........
Bob
Posted 30 December 2012 - 09:35 PM
Posted 31 December 2012 - 01:00 AM
Posted 01 January 2013 - 01:03 AM
The manifold is of course another matter altogether, as it basically has no cooling. One of the modern ceramic type coatings is best there. I used to use Sperex, many years ago, but as a paint it was not wonderful.
