Mini Engine? Identification
5 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 30 December 2012 - 04:51 PM
Hi, my next door neighbour has a couple of old engines in their garage and thinks hat one might be a Mini engine. I have taken a couple of photos and thought I had be nine set no but the number i have is cast onto the rear of the engine casing and after getting it (i was in a rush) i read that the engine details are on a plate riveted to the front of the casing under the thermostat casing. Anyway I can't get back to look again but they are going to send me some more photos.
If it helps the number I got from the casing is:
12A497 WMC 23758F
#2 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 30 December 2012 - 05:13 PM
Found this post in this forum:
http://www.theminifo...identify-block/
Looks like it's prob a 998 block?
#3 Carlos W
Carlos W
  • 10,115 posts
Posted 31 December 2012 - 12:12 PM
http://www.guess-wor...Tech/engine.htm
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 31 December 2012 - 01:36 PM
12A should be a 1275 block
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 31 December 2012 - 01:44 PM
If the number is cast onto the back of the block thats not the engine number its a casting number.
Like you say engine number riveted onto block next to thermostat housing.
simple thing look at though if no plate.
Back of the block, are there 2 cover plates under where the head fixes on, If so most likely won't be a 1275. Only 1275 cooper S got the cover plates. But most 1275's don't
http://www.7ent.com/...tification.html
Edited by lrostoke, 31 December 2012 - 01:47 PM.
#6 A-Cell
A-Cell
  • 1,610 posts
Posted 31 December 2012 - 01:49 PM
12A497 Block casting number is either 998 or 1098 with tapped chest covers. Definitely not a 1275.
