hi ive got a 1098 engine with a spotex exhaust, su carb with trumpet and a sock filter i was wondering whats the best carb for the engine because iv heard that the dellorto carbs aren't as good as the su carbs what should i run ?
thanks ewan
Carbs For A 1098
EspMini30
, Jan 02 2013 09:58 AM
3 replies to this topic
Posted 02 January 2013 - 09:58 AM
Posted 02 January 2013 - 12:57 PM
with just those small mods a stock carb or the newer HIF38 will be best
Posted 02 January 2013 - 05:23 PM
With it all standard apart from the exhaust, an HS4 carb will be ideal. Your exhaust should be a maximum of 1.75" internal diameter, although for best power a 1.625" int. dia. would be better. Final exit must be the same diameter as the rest of the pipe and single exit pipe.
With a more modified engine the 1.75" int. dia with a 3-into-1 exhaust manifold is better and with that you can use either a single HS4 (or HIF38) or twin HS2's, as fitted to the original MG1100, Cooper 998, A-H Sprite, etc.
Posted 03 January 2013 - 12:12 AM
When my engine went sick a few years ago I put in a 1098 and ran it on a LCB and 1.75 exhaust and 1.25 twin cooper carbs and it went well for what it was, it didn't rev like a 998 but it was never designed to and it was quite torquie on the road
