Unplugging The Lambda (Oxygen) Sensor Makes No Difference?
3 replies to this topic
#1 fattail95
fattail95
  • 873 posts
Posted 02 January 2013 - 12:10 PM
Hi there guys,
Still trying to sort out this lumpy idling. Today I unplugged the lambda sensor and went for a drive, and it drove exactly the same, no difference! Maybe it felt a little peppier but that could just be my imagination.
Surely if the lambda sensor was working properly, when unplugged the engine would respond/drive differently?
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 02 January 2013 - 12:32 PM
Did you check the wiring? It has a tendancy to melt the cable as it is close to the manifold....
#3 charie t
charie t
  • 3,153 posts
Posted 02 January 2013 - 12:51 PM
If you un plug a sensor, most of the time it will revert back to what factory settings were. You will have created a fault code now as well
If the car was not up to temperature it won't make a difference anyway, as it doesn't use it until up to temperature.
Why did you unplug it in the first place?
#4 R1minimagic
R1minimagic
  • 4,660 posts
Posted 02 January 2013 - 12:55 PM
Thats true but even if it did, you probably wouldnt notice much of a difference as the sensor just gives finer control.
The only way to test the sensor is to measure the output voltage vs speed/load
Edited by R1minimagic, 02 January 2013 - 12:56 PM.
