Cam?
Posted 03 January 2013 - 10:25 PM
Just taken engine apart. I have found that I have a 285 cam.
Is this a good cam? Whats its power band? is there a more aggressive cam??
Cam was in a 1275 engine. When rebuilt its going to be a 1293 ish engine!!!
Posted 04 January 2013 - 04:00 PM
Posted 04 January 2013 - 04:28 PM
Part No. Application Power Band Power Increase Duration Valve Lift Timing Full Lift Lift @ TDC with clearance Valve Clearance Inl Exh Inl Exh Inl ATDC Exh BTDC Inl Exh BP285 ULTIMATE ROAD 2000‑7000 14BHP 280° 280° 0.400″ 10.16mm 0.400″ 10.16mm 33‑67 67‑33 107° 0.088″ 2.24mm 0.088″ 2.24mm 0.012″ / 0.30mm 0.012″ / 0.30mm
What is the car used for as a more radical cam is likely to make a a narrower power band on the road.
Edited by KernowCooper, 04 January 2013 - 04:35 PM.
Posted 04 January 2013 - 05:06 PM
Mine is being used on the track not a road engine!!
Posted 04 January 2013 - 05:13 PM
Posted 04 January 2013 - 08:54 PM
Posted 05 January 2013 - 12:01 AM
Aye -but the engine must be built to take the revs - which isn't cheap !!!
Out of interest, how do you build an engine to take the revs??? How high revs are we talking here?? Most of the time we revving at a min of 8
Posted 05 January 2013 - 12:09 AM
The only A-series engine for competition which needs to rev to over 8k is the 970 Cooper 'S' engine. I also not that the OP says that most of the time 'we revving at a min of 8'. If a 'minimum' of 8k, what are max revs then and why are such high revs needed?
Posted 05 January 2013 - 01:36 AM
Good luck with the regular rebuilds
Posted 05 January 2013 - 11:58 AM
Have always been trying to bring the revs down, but have never managed it..... apart from getting it from 8.5 to 8.
Just can't seem to find the right 2nd gear!!!!!
Posted 05 January 2013 - 02:32 PM
