Sill Bolt Holes
3 replies to this topic
#1 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 04 January 2013 - 09:09 AM
As the heading says, the threaded holes at each end of the sills ('95 Rover mini), what are they for? Here in Australia, I haven't seen them on local cars but my import one has them, are the just for say, the assembling? They appear to be 3/8" unc threads.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,039 posts
  • Name: Neil
Posted 04 January 2013 - 09:15 AM
Do you mean the slinging point holes at each end of the sill?? if so they are no longer used as there were for moving the shell around on the production line at the factory.
#3 Tupers
Tupers
  • 4,148 posts
Posted 04 January 2013 - 11:24 AM
They could be for bolting the bare shells onto transport frames?
If you scroll to the bottom there's 6 shells on frames. Clicky
#4 tiger99
tiger99
  • 8,584 posts
Posted 04 January 2013 - 01:15 PM
I was never sure what the thread on these was. It did not seem to be exactly 3.8" UNC, because I could never find a bolt to fit, which makes me wonder if it was Whitworth. Anyway, they were only used in the factory, and can support the weight of a bare shell only. When new Minis were delivered, they were supposed to be filled by plastic plugs 13H 2475, and I suggest doing the same to help prevent corrosion. You may not be able to get the original plugs, but there will be something suitable somewhere, or failing that, a blob of silicone sealant.
