Parcel Shelf Carpet
7 replies to this topic
#1 nospamprl
nospamprl
  • 97 posts
  • Local Club: Miniasociados Mexico
Posted 05 January 2013 - 04:09 AM
I need to cut a piece of carpet to fit the rear parcel shelf, (behind the rear seat back), for a 1989 Mini 30.
Do you know about any downloadable template or diagram I can use?
(Sorry for mentioning valance instead of parcel shelf in the title. Im not a native english speaker and I confused the proper word)
#2 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 05 January 2013 - 08:26 AM
Couldn't you take the speakers off, then the board with the carpet on and just use that as temlpate? would have thought it was the same, perhaps make it a little bigger?
The only thing with this is that the board doesn't exactly follow the line of the panel, they didnt have to as the seat covers this up.
Anyone correct me if im wrong ;D
#3 mattbeddow
mattbeddow
  • 337 posts
Posted 05 January 2013 - 11:11 AM
+1 for using the existing board for a template,
I fitted my speakers yesterday and the board was in and out so many times, and with the window out, i could see that the board is shaped to make removal and refitting possible without snapping it. You might not have the same problem with carpet.
The best way, if you dont want to/cant use the board would be to make your own template, then you know it will fit
#4 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 05 January 2013 - 11:33 AM
Edited your title for you :thumbsup:
#5 nospamprl
nospamprl
  • 97 posts
Posted 05 January 2013 - 03:40 PM
No, I dont have anything to get removed. We have plain metal.
#6 brum,brum,mike
brum,brum,mike
  • Just Joined
  • 554 posts
Posted 05 January 2013 - 09:05 PM
http://www.theminifo...aker-board-etc/
Did a quick search and found this... hopefully it will work although it does seem to take while to load
#7 freshairmini
freshairmini
  • 1,718 posts
Posted 05 January 2013 - 09:13 PM
get a piece of paper and make your own template. really not difficult. Once you got the template you can then do the carpet properly with board.
#8 nospamprl
nospamprl
  • 97 posts
Posted 06 January 2013 - 04:25 AM
Thank you, unfortunately the file is no longer there.
