Tappy
Posted 05 January 2013 - 01:58 PM
I'm sure this subject has been talked about a lot but i couldn't find much usefull info when i did a quick search.
I've done my tappets a few times today, setting the gaps at 0.30. Adjusting valve clearance 1, when valve 8 is fully open (at its highist point) and so on...as it says in my Haynes manual. But i can't seem to rid of the tappy sound when the engine is running. It seem to run fine, it just sounds a bit too tappy for my liking.
could this just be engine wear? Its only done about 50-60k. Or am i doing something wrong?
I am turning the engine over by turning the front wheel (i removed the spark plugs and jacked up the front of the car...pushing the car and watching the head at the same time is very awkward on your own)
any input apreciated,
98 mpi standard rover cooper
Posted 05 January 2013 - 02:16 PM
Edited by rids, 05 January 2013 - 02:19 PM.
Posted 05 January 2013 - 02:23 PM
You could set the clearances using a dial gauge indicator, that way you will eliminate the effect of any grooving.
Overall though better to have it a bit "tappety" sounding than risk too tight a clearance and cause damage. Hope this helps.
Posted 06 January 2013 - 09:50 AM
Rids. The haynes says the valve clearances (inlet and exhaust) on 1996 models onwards should be 0.27 to 0.33mm. So i'm using metric gauges.
A-Cell. ok i'll take a closer look at the rockers. So am i correct in saying that, the bigger the gap, the more tappety the engine sounds..? So maybe reducing the gap slightly might make it less tappety? I always thought that the tighter the gap...the more tappety the engine sounds
Posted 06 January 2013 - 09:53 AM
Posted 06 January 2013 - 09:57 AM
Posted 06 January 2013 - 08:33 PM
Posted 07 January 2013 - 09:41 AM
Yes i used a 0.30mm feeler gauge, but this time i adjusted them so the gauge was a tight fit rather than a slide fit (i couldn't get to 0.27-0.29mm with the gauges i've got) Still a very slight tappy sound but i'm happy with that...it is a mini after all. I can't hear it when i'm in the car driving so thats the main thing.
cheers
Posted 07 January 2013 - 12:39 PM
Posted 08 January 2013 - 10:21 PM
Posted 09 January 2013 - 09:49 AM
Posted 09 January 2013 - 10:04 AM
you want to hear mine lol running in after rebuild like a gatling gun!
No like a Mini! Mini designed and built in the UK for the pleasure of millions. Gatling gun designed and built in America for the destruction of millions!
